fuel pick up (sender) from 2.2 or td5 into 2.4
					Might be an odd Q but my 2.4 sender is broken (another gift from the dodgy mechanic) and knowing that the 2.2 and TD5 had a low pressure pump in the sender is there merit in using a 2.2 (or TD5) is lieu.  Is it a straight swap?  If not, what is required to make it work.  I know the TD5 had an inertia switch (no idea about 2.2).  Is an inertia switch required?
A quick price comparison: 2.4 sender unit GBP100 v's the 2.2 at GBP200.
Before someone poses the Q - The primary motivation is priming of the system on filter change.  Just trying to work out the cost/benefit.
				MLD
Current: (Diggy) MY10 D130 ute, locked F&R, air suspension and rolling on 35's.
Current: (but in need of TLC) 200tdi 110 ute & a 300tdi 110 ute.
Current: (Steed) MY11 Audi RS5 phantom black (the daily driver)
Gone: (Dorothy) MY99 TD5 D110
