A little more detail on what the problem is might help, I suspect you're referring to the temperature control / heater tap, if it is not shutting off completely (i.e. you get hot air when you've got it set to cold) there is an adjustment under the bonnet near the firewall on the left; unclip the cable and adjust it so that the tap is fully closed when the control is all the way to cold. If you mean the fan switch, I'm not certain but I think it's mounted directly behind the panel, i.e. no cable, so perhaps it's come loose. The fan on this model comes on when the aircon is switched on, in many vehicles you have to switch on both the a/c and the fan to get a/c, the defender is (of course) different.
