Results 1 to 10 of 14
Thread: D2 ‘stock’ ride height
    Jan 2011
    Gippsland
    Anyone out there with an unmodified coil sprung TD5? that could help me.....I’d like to know the measurement from the ground to the bottom edge of the closed drivers door at the B pillar please..
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Jul 2014
    PERTH, WA
    D2 'stock' ride height - one answer
    Hi Onebob,
    I get 435 mm on mine.
    The car has a LR bulbar and side steps, but no other modifications.
    Andrew
    Jan 2011
    Gippsland
    Thanks Andrew..
    LROCV member #131
    Brisbane,some of the time.
    Some more info that may help
    Front hub centre to wheel arch 500mm,top of bump stop to axle bracket 44.5mm
    Rear hub centre to wheel arch coils 483mm,Air 473mm
    bump stop to axle bracket coils 71.5mm,air 61.5mm
    From LR workshop manual.
    Jan 2011
    Gippsland
    Thanks scarry..
    LROCV member #131
    Jan 2011
    Gippsland
    Quote Originally Posted by AndrewMilne View Post
    Hi Onebob,
    Andrew
    I measured mine to be 495 mm which reflects my LRA 2inch lift. I’m running 245/70 all terrains which i will be replacing before winter and are considering a taller but not wider tyre and i want to work out what the potential height gain might be..
    LROCV member #131
    Jul 2014
    PERTH, WA
    D2 height - tyre size
    I should have mentioned what tyres I am running.
    They are Bridgestone 697's, 235 x 70 R16, at 30 PSI (front), 38 PSI (rear).
    I'm pretty sure you can gain 15 - 20 mm by going to /75 or taller.
    Quote Originally Posted by onebob View Post
    Apr 2016
    Country Vic.
    my understanding is that the stock D2 tyre size is 235/70/16, or alternatively 255/55/18.
    That's how my two D2s are placarded.
    So 245/70 is slightly taller and a bit wider than standard.
    245/75 is a good alternative if you go 245 section tyre.
    Brother got some KO2's for his D2, my D1 came with 255/70's when I got it .. but I prefer his 245/75's.
    Slightly more compliant ride .. AND the (245)KO2 tyre is a lot nicer than my (255)Geolanders.
    What tyres/sizes you considering as replacements
    When the time comes for me to replace tyres, I'm strongly leaning towards the KO2(at 245/75 16's) too.
    Only downside is the speedo is out of whack by a significant margin. Shows well under .. maybe 100 indicated at 105 actual.
    He still hasn't got a speedo corrector to sort that out.
    The other issue with that is that of torque converter lockup and gear changes.
    With the brothers geared up TD5, now it seems to change into a higher gear what feels like is too late, hold lower gears a lot longer than it feels is necessary.
    I'd say the speedo corrector set right(to show more than actual) would fix that too. Dunno, just a guess on my part that's what would happen.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2011
    Gippsland
    I’m considering 235/85 but will check the guidelines re lift and the fitting of non standard tyres. ATM don’t know where to go to find that info and interpreting it is another thing....D2 ‘stock’ ride height
    LROCV member #131
    Jan 2011
    Gippsland
    Found online on the VicRoads webpages a pdf download “guide to modification for motor vehicles” and atm I’m picking apart section 13.3.1 option 1 regarding a total permitted lift of 75mm. It seems i should be looking at 245/75 tyres with my current 2 inch lift.
    LROCV member #131
