Results 1 to 10 of 20
Thread: Td5 cruise control operation
    Feb 2014
    Queensland
    Thumbs up Td5 cruise control operation
    G'day,
    Can someone please let me know how the Disco TD5 cruise control switches operate? More specifically, is the 'cruise enable' button on the console a momentary button?
    The reason I ask is that I have recently acquired a newer ECU for my Defender and I intend on wiring in some switches to enable cruise control. My plan is to have single momentary SPDT switch for the RES and SET functions and a separate switch for the cruise On/Off switch. I was thinking of having an LED mounted to indicate whether the cruise is enabled or not.
    So back to the point, does the Disco 'cruise enabled' lamp extinguish when the brake or clutch is depressed, or does it stay lit until the 'cruise enable' switch is turned OFF?
    Thanks in advance!
    Dec 2009
    Baldivis WA
    Quote Originally Posted by Aussie_Oz_Born View Post
    G'day,
    Can someone please let me know how the Disco TD5 cruise control switches operate? More specifically, is the 'cruise enable' button on the console a momentary button? No, it’s latching.
    So back to the point, does the Disco 'cruise enabled' lamp extinguish when the brake or clutch is depressed, or does it stay lit until the 'cruise enable' switch is turned OFF? Stays lit unit the ‘cruse enable’ switch is turned OFF.
    Thanks in advance!
    ​See answers in Red
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    May 2015
    Williamstown, Victoria
    Have a look at
    www.discovery2.co.uk A bar / Fitting Cruise Control To a Discovery 2 TD5
    "ALL discovery 2 TD5's are "cruise" ready, it just needs "hooking up!!!.......Read On!!!"
    Build date 11th Oct 2003
    LROCV #1410
    I have the drawing here.. I’ll dig it up.
    You don’t need a “cruise enable” switch (modern LRs don’t have it) just 2 switches for set and cancel.
    Avoca Beach
    Funnily enough they will only inch "up" not "down".
    if you want to go slower you have to touch the brakes and reset.
    Regards Philip A
    Apr 2016
    Country Vic.
    Yeah, a bit of annoyance when I drive brother's D2.
    Although an alternative to braking, is to switch it off .. and then on again quickly.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2017
    Geraldton WA
    On the rare occasions that I have used the cruise control on my D2a I have started at a lower speed and have inched up to where I want it.
    As I like to travel at a maximum of 2-3k's under the posted limit this seems to work for me because if you set the CC to the maximum posted limit you will be speeding on the downhill runs.
    4.6m Quintrex boat
    Apr 2016
    Country Vic.
    I generally set it to a bit less than that again.
    Quote Originally Posted by trout1105 View Post
    .... this seems to work for me because if you set the CC to the maximum posted limit you will be speeding on the downhill runs.
    One word(or phrase) .. 300TDi!
    No such chance of that happening with a 300 Tdi on cruise .. it seems to slow down even more on the down, than it does on the up
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Feb 2014
    Queensland
    Thanks for the replies everyone, just need to sort out where the buttons will go now. Cheers.
    Mine: 1999 Td5 Defender
    Hers: 2013/14 D4 TDV6
    Inheritance? : S3 w/186
    Dream: Perentie Senior Commander🤞 / Milka😁😜
