Results 1 to 3 of 3
Thread: Strange Phenomenon
    Mar 2013
    East Gippsland
    Strange Phenomenon
    Driving back from Cooma 70th my 2a with a stromberg carby (not sure if carby has anything to do with it but it's not stock) oddly lost power going up hills, oil pressure was fine,temp was fine, vacuum gauge kinda went to 0.
    car surged and lost power, change down a gear to decrease load did nothing to help backfiring and surging engine would just power down and die.
    liftid bonnet and coil wasn't hot and all leads were good and plugged in.
    Motor started and pulled away fine until it had to load a little, engine died again so I removed the air cleaner thinking it needed more air .....no differences in behaviour ....limped into Bombala and thought maybe it was bad fuel from where I filled up in Cooma, so switched tanks problem disappeared.
    On the down hill run to Cann River switched tank back to Cooma fuel to try and burn some of it off and low and behold car powered up hills that it struggled with pre Bombala?..
    Could it be altitude related?...
    On the way up I drove 30 degree heat with no issues
    Very strange hope someone can shed some light on this
    Cheers Paul
    Narre Warren South
    Maybe fuel tank breather blocked causing a vacuum. Switch tanks and that supplies fuel OK. Switch back and vacuum has leaked down so runs OK on the original tank ?
    Was it you I passed not far out of Cooma early this morning ? Red Territory towing a Series I.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2013
    East Gippsland
    Quote Originally Posted by gromit View Post
    Colin
    Yes things were fine then.........shortly later Mr Murphy hitched a lift with me, saw your car on oval wanted to say gday but couldn't find you
    Cheers Paul
