Results 1 to 10 of 13
Thread: Tyre Plugs, temporary or permanent
    Feb 2005
    Campsite repair after the defer decided to self level over night
    Avoca Beach
    I put a temporary plug in a BFG AT once from builders nail in my driveway GRRR..
    Then forgot about it.
    About 3-4 years later got a slow leak in the tyre, and turned out to be the plug leaking a bit.
    Then replaced with mushroom patch by tyre place in Alice after Plenty Highway.
    So IMHO they are pretty permanent.
    Regards Philip A
    Crafers West South Australia
    I bought a permanent patch kit some years ago, the trouble is that they are for commercial use and 100 plugs take a long time to get through, and the glue goes off. But damn, they're good to have, saves you doing the job twice.
    Dec 2009
    Ranelagh, Tasmania
    Towing the caravan over the blue mountains for Easter, I heard a pop and a few minutes later the TPMS alarmed for the RHS rear. A 6 x 50mm stainless bolt had gone through head first.
    I didn’t want to disconnect the caravan and jack up the car so I removed the bolt with vice grips and plugged the hole with my Aldi kit. It pumped up fine and did another 100km but I decided that with a heavy vehicle towing with a 250kg ball weight it was safer to get it patched properly. $35 at Bob Jane’s for a mushroom plug for peace of mind.
    I put one in my wife’s VW Golf for a small screw a month or two ago and it is still sealing but I will get it replaced soon.
    I think these plugs are great for a temporary repair but I’m not sure that they should be permanent.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Sep 2012
    Adelaide Hills
    where do you buy tyre plugs?
    sounds like a good addition to my tool bag
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    in the wild New England, NSW
    I try to remember to carry a battery drill using about a 1/4” bit as it makes a much better hole
    for the plug to feed through and to seal in😊 .
    I have found that the plugs seem to last the
    life of the tyre.
    Western Victoria
    Quote Originally Posted by Eevo View Post
    Most auto accessories outlets.
    Jan 2017
    Geraldton WA
    You can buy the complete plug repair kit relatively cheaply from most automotive stores and online.
    The kit will usually consist of the plugs and all the tools needed to make a repair, Just having the plugs themselves isn't much use.
    This kit is one of the FIRST things that I would add to any tool kit 4WD or otherwise and in most occasions you don't even have to remove the wheel to effect the repair and just do the job with the wheel still on the car
    All you have to do is to locate the puncture and mark it then drive forward or backwards a small distance so that you can access the offending hole and repair it "In situ" without the need to jack the car up at all, even if the hole is on the inside of the tyre.
    4.6m Quintrex boat
    The only reason(s) to change them out:
    - A temporary plug is rated exactly that, having it blow out can do damage and could be considered the reason to void insurance.
    - Soft seals don’t effectively keep moisture out of the steel belts, the mushroom plugs are bonded (glued) into the repair and keep the steel belts from getting water and rusting, potentially leading to a blow out later on.
    - Fixing in situ will get you going, but without popping the bead and inspecting the inside of the tyre there is no way to know if the carcass has suffered any other damage.
    Mar 2016
    Adelaide
    Not sure that jack looks too safe. Was it feeling tired & needed a lie down?
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
