Results 1 to 4 of 4
Thread: Broken fpr hose connector
    Jun 2013
    Universe A
    Hi,
    Has anyone had a broken fpr quick release connector?
    We had one blow off yesterday, it's the hose that runs back to the tank on the chassis rail, how do you put a new end on it?
    Cheers James
    Australia
    You can repair them by replacing the connector but it is a fiddle and probably have to get a whole new line to get the connector if you don't have one handy.
    It is possible to take the QR connector from an old FPR hose.
    You will find it easier to remove the line back down to the chassis and work on it from the side of the car rather than through the engine bay.
    There are Youtube vids of home repairs using a flaring tool clamp, corking gun and some make shift dollies.
    The rubber line is actually an insulating sheath and the actual line inside this is nylon.
    I have a complete line set (paired supply/return) with connectors you can PM if any help to you.
    Jun 2013
    Universe A
    Quote Originally Posted by strangy View Post
    Thanks for that, have decided to make up a different way to hold the pipe on, gonna fabricate a metal clamp as the only thing wrong with it is the retaining clips, will see how I go......
    Jun 2013
    Universe A
    So, this is what I did..
    The wider part goes over the groove in the fuel line,I had too grind it down thinner too fit in the small slot that is already there, then the other end goes along the steel barb coming out of the fpr and a hose clamp goes around this, seems to be working ok so far anyway.
    Cheers James
