14th March 2006, 12:58 PM
Bullbar and front suspension
Hi,
I'm thinking of finally shelling out for a bullbar for my Disco TD5 and want to know if I must also consider upgrading at least my front suspensions? I'm looking at an ARB Sahara bar which apparently weighs 60kg, can my standard springs cope?
Thanks,
g
14th March 2006, 01:43 PM
Hi Goofy
My honest sugestion would be to replace the suspension, while you can get away with the standard set up, you will bottom out alot more and ultimately have the potential for premature failure of components.
If you are going to fit a winch as well then you will definitely have to replace the front set up.
Cheers Blythe
14th March 2006, 02:03 PM
careful of going up too high. Even a 50mm lift can cause probs with the front propshaft failing early. Go the lift but put some $$ into upgrading the uni's to greasable on the front shaft at the same time.
14th March 2006, 08:02 PM
#4
I have found no need to redo the front suspension with a Sahara bar and a warn 9000lb winch. I have found no dramas with ground clearance or performance due to sag :wink:
Series 11A ex Air Force
1995 ES Discovery TDI
RIP 2006 Discovery 3
RIP 2004 V8 Discovery
RIP 95 Discovery TDI
RIP 1999 Freelander
RIP 1978 EX Army FFR
15th March 2006, 05:24 PM
#5
Thanks! That's a nice looking drive you've got. I definitely have to save up for the bar now !
16th March 2006, 07:18 PM
#6
I have a TJM steel bar with a 9000lb winch. I reckon it's robbed me of only 5mm but I will be doing a 50mm lift anyway pretty soon.
D4 SDV6, a blank canvas
17th March 2006, 02:49 PM
#7
ARB managed to get a 50mm lift with OME suspension on my D2 and I have had no problem with any unwarranted ware. It drives a lot better and handles the extra weight with a long range fuel tank at the rear and a full steel bull bar at the front.
17th March 2006, 06:56 PM
#8
Hi,
I dont agree that the standard springs will be sufficient as they are progressive and find difficulty in coping with the increased load further away from the axle centre.(inertia) 8O
eg: you have 60kgs further out and the progressive spring rate finds it difficult to turn around and send skywards after hitting a dip.
my recomendation is that you install "PinK" rangie springs purchased from from Les Richmond in victoria.
Graham Cooper has them in stock usually.
this will give you about:
Front …..515mm Unladen ……… Rangie Springs (Pink)
with a Sahara Bar on
Real measurements …Standard
Front …. 483mm +- 15mm Factory specifications
The measurements are from the wheel arch to the centre of the axle
(Factory)
Then put "Polyairs" In The rear and your nice spring rates wont be upset.
Cheers Aston
with are
