Results 1 to 10 of 18
Thread: noisy 110 Gearbox
    Jun 2015
    broke
    noisy 110 Gearbox
    I have a 1986 120 with a 3.9 Isuzu.
    The gearbox is noisy in 1,2,3,5th. (got noisy in the last 2 months).
    Quiet in 4th.
    I have changed all oils as supplied by ALL 4X4, when I recently replaced a long rear axle and drive flange in the rear.
    I am the 2nd owner and the ute has only 145,000klms on it.
    It is very highly geared. Sits on 110klm easily. (But only if it cannot see a hill).
    I have been told it has high range diffs and a Santana box.
    It is a very unusual Landy, in that it does not leak any fluids from anywhere. Really !
    Any help from the great minds on this site are most welcome.
    Cheers, Paul.
    Bearman's Avatar
    Hay Point
    Quote Originally Posted by wollomi1962 View Post
    Quiet in 4th.
    Cheers, Paul.
    G'day Paul, It will be an LT85 5speed that your vehicle has in it. Unlikely it is a Santana box - they have a split case bolted together north to south whereas yours should be a solid 1 piece gearbox case. The diffs will be 3.54 which is the standard ratio for that vehicle. It is very unusual if it has no oil leaks haha. The symptoms you describe indicate it needs new bearings especially the layshaft. Don't leave it too long or the cost of repairs will escalate.
    Cheers......Brian
    1985 110 V8 County
    St Helena,Melbourne
    1.13 MB
    Isn't the lt85 a Santana box ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW far north coast
    Yep.
    Bearman's Avatar
    Hay Point
    I always thought the split case version was referred to as a Santana.
    Cheers......Brian
    1985 110 V8 County
    NSW far north coast
    Now I'm wondering Brian?
    Jun 2016
    United States
    I've heard it referred to as a Santana by Ashcroft and in the States.
    Scratching my teenage itch now that I'm in my midlife crisis...
    '87 110 County 4BD1+T+LP (Godzilla)
    '88 110 Perentie Cargo 4BD1+T+LP (Thing1)
    '91 110 Perentie Cargo 4BD1+T+LP (Thing2)
    Jan 2014
    Perth Western Australia
    Isuzu engine.... can a noisy gearbox even be noticed
    Daz
    Melrose SA
    The LT85 was originally designed under contract by Land Rover for Santana in Spain and was considered to be a strong working gearbox. Rover purchased LT85 gearboxes directly from Santana. It is also known as the Spanish Box.This gearbox was used as originally designed until 1988. A cost reduced, lighter weight, divided caseversion of the LT85 was introduced in 1988 and used through 1991. The main short coming of the divided case version was its main and lay shaft bearings. The loading on the bearings in 5th gear caused frequent gearbox failure when cruising for long periods of time under high throttle. There was also a bearing quality problem at one stage of manufacture and the gearbox was sensitive to the type of oil used.In 1991 the relationship between Rover and Santana ended and the LT85 was no longer available to Rover.
    Bearman's Avatar
    Hay Point
    Well, there you go. I always understood that the solid case lt85 was a land rover box and the split case one was the one built under licence to santana.
    Cheers......Brian
    1985 110 V8 County
