Results 1 to 6 of 6
Thread: Code 022 left hand pretensioner measures open circuit (permanent)
    Oct 2007
    Brisbane West
    It's great that a year and 30k or so after doing new head gaskets and new ignition I'm getting good stats on the nanocom...but it also shows the above code. Has anyone troubleshot that code or the driver's side equivalent? Cheere
    Kingston, Tassie, OZ.
    Easy. First call is the under seat plug connector. Seen many where the wires are torn out or the connector pulled by stuffing things under the seat...
    Oct 2007
    Brisbane West
    Thanks Justin. There is a yellow underseat plug I have noticed before so I will.check it out. Cheers
    Oct 2007
    Brisbane West
    Ok cannot see any loose wires in the plug and contacts are nice and clean. Uncoupled and recoupled plug and now SRS light no longer on dash and no code gone but in have done the same thing pre-Nanocom and it works for a day or 2 typically and then plays up again...joys of millivolt (have tried cleaning) electronics or should I look elsewhere?
    I have hard wired them in the past... the connectors are pretty poor
    Oct 2007
    Brisbane West
    Thanks JC.
    Cheers.
