You will snap axles.
If you want to make a 4wd beast out of it you are better off putting a saulsbury under the rear end at the least.
I know that the series 3 gearbox can be killed be a holden 6, but that's not as strong as a series 2 box.
Hi guys, as most of you know i am doing up the series II as a 4wd weekend toy. I am toying with the idea of dropping a 3.5L rover v8 into it and selling the 2.25L Petrol engine it came with. My question is how will the drive train go handling the extra power? I am going to head off road and snap something the minute the terrain gets tough or will the gearbox/TC/Diffs etc be up to the task. There are planty of rover v8's out there so getting parts will be easier and it will most likely end up being cheaper, not to mention the economy probably wont be much different.
It will be a while before i get to it but want to start planning these things now. Matt
The 4wd Zone/Opposite Lock Bathurst
263 Stewart Street, Bathurst, NSW
http://www.the4wdzone.com.au/
Discounts for AULRO members, just shoot me a PM before you purchase.
1994 Discovery TDi
2004 Discovery 2 TD5
2010 Discovery 4 TDV6
No worries thanks pheeny. Can you get maxis and lockers for the series diffs? MattOriginally posted by Phoenix
Can be done. The V8 will fit into a seris easy. But put Rangie diffs in as they will make it go better and they are the week point of the axel. Shalfs are the same so will fit. As long as you get a 10 spline rangie diff.
The seris 2 box is stronger than the seris 3 box so this is always the weapon of choice for this.
And remeber to get a remote oil filter or you will rip of the oil filter on the diff on the first trip out![]()
95 300 Tdi Defender 90
99 300 Tdi Defender 110
92 Discovery 200tdi
50 Series 1 80
50 Series 1 80
www.reads4x4.com
I've been asking myself this same question for years, but so far they've all managed and no complaints.![]()
Yes you can get lockers for series diffs.
Best option - 3.5 and 4 speed (LT95) easy to come by and strong, just replace the lot.
As for diffs, dont bother with a RR rear, just use a sals. Try and find a 24spline series one, will bolt in but the pinion is 2 inches longer, so either redrill the pearches to push it back or shorten the shaft. I'd try to push it back, then you have 90' WB and the wheel sits central in the rear guard if you have a tub (Looks HEAPS better)
For front, I would use Stage 1 front. CV's are stronger than RR. Diffs are 10spline but I have some 24/23spline custom axles that I will be getting rid of at some point :wink: That way you can use a 24spline diff (=stronger)
The only problem with this is that you are limited to drums. You can modify for disks but it is tricky. With stage one front is relatively easy as you can use RR hubs as the spindle use the same bearings 8)
I think Popeye has this sussed.
This is where you look at the project and say - well if im gong to do all this work, I still have Drums and Leafs - I may as well buy a flogged Rangie and place my series body on itHybrid.
Anyway - its doable.
PS - Shoot over to OL and look at Slunnies Project, he has done the 3.5 and 4 speed converion amoungst other things.
this is a swb he is talking about is it not?
rear diff replacements mean shifting the spring pads.... they are at different centers on a swb as there are no outriggers...
screw the v8 put a 200tdi in it![]()
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
I reckon I'd go Incisors route, go the diesel![]()
If he is going to fit the V8 and Box in, then changing 2 spring pads on a rear diff and redrilling the spring pads forwards is only a few hours work.Originally posted by incisor
4BD1T 8)
i had a 4.4 with a series 2/3 (bits of both) box in a game for a while.
went like the clappers but there isn't enough spread in the gears to take advantage of the v8 torque.
tdi is too expensive to buy compared with rover 8.
In a light truck (read shortie series) 3.5/3.9 with 4 speed auto would be very drivable
all motor options can break series diffs and gearboxes when you get traction.
i would like rover 8, 4 speed auto,lt230 on 60 series diffs spoa on 60 series rear leafs all round.(slot in some haultech cv's :wink: )
cheap junkyard trash and mods most people can do under a carport.
david
