                                                21st April 2018, 03:31 PM
			Td5 problem elimination question
					Hi, I have a 2002 defender td5 and I've had the issue of diesel in the coolant for a while. Is it correct that this issue will come from one of two places
 1. The fuel cooler is stuffed
 Or 2. There is issues with the head.
 So in order to try and find out if the fuel cooler is the issue what I did was- after
 several flushes of the cooling system to ensure as clean water as possible I disconnected the fuel line from the fuel cooler and joined them together, thus the fuel system no long passes through  the fuel cooler (a temporary measure).
 I did this thinking that of the cooler is the issue I would no longer have diesel in the coolant.
 Is my thinking correct that no fuel lines
 Into the cooler and I'm still getting diesel in the system means that the issue is somewhere other than the cooler.
 If so what and exactly is the problem, is it the head and or fuel rail? ☹️
                                                21st April 2018, 03:32 PM
					The fuel rail is cast into the head.
 So it’s likely cracked if you’ve bypassed the cooler and still having the issue.
 Are you sure it Diesel and not Oil?
                                                21st April 2018, 03:45 PM
					If you confirm that it is diesel and not oil put an AMC head on it problem solved.
                                                21st April 2018, 03:58 PM
                                                #4
