Results 1 to 10 of 11
Thread: Vacuum advance tube supplier?
    Nov 2008
    Can anyone suggest where I can buy 1/8 in copper tube to remake the vacuum connection between carb and dissy? I have the fittings but can’t find anyone who stocks tube this size.
    thanks
    Roger
    Narre Warren South
    A company that deals in steam model parts or a company that does refrigerator repairs.
    Lots on Ebay but mostly from the US.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Sep 2012
    Westlake ,brisbane
    I bought some from Repco about 5 years ago , could buy it by the meter .
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by dreamin' View Post
    thanks
    Roger
    Hello Roger,
    Did you have any luck tracking down a supplier of the copper vacuum advance tubing?
    Also, is this 1/8 internal or external diameter?
    I am after some for my Series 3 with a 2.6 litre six cylinder petrol motor. Does anyone know if the diameter changed for the six cylinder motor instead of a Series 1 four cylinder?
    So far the most frequent suppliers I have found have been for supplying tubing for automotive gauges.
    Kind Regards
    Lionel
    Oct 2007
    Wantabadgery, N.S.W.
    I've got a coil of 1/8" ID if you want a bit. It's got a thick wall, so ends up about 1/4" OD
    Don.
    Nov 2008
    Quote Originally Posted by Lionelgee View Post
    Hello Roger,
    Kind Regards
    Lionel
    The local miniature steam railway society has pointed me to a supplier in Hobart - an industrial hose and liquid handling supplier. As I understand it, tube is measured in outside diameter, pipe by inside diameter. The stuff I need for the 2 litre setup is tube with 1/8 inch outside diameter to suit the soldered screw fittings.
    I also have a 2.6 litre engine but the vacuum advance tube has push-on fittings at both ends. I have seen them set up with a copper tube with a short rubber section at each end. On mine I use rubber vacuum hose for the whole thing.
    Roger
    Nov 2008
    Quote Originally Posted by Don 130 View Post
    Don.
    Thanks for the offer, Don. The stuff I’m after is 1/8 in OD, to suit screw fittings soldered on at both ends, so don’t think the thicker section would work. Thanks again. Roger
    Sep 2012
    Westlake ,brisbane
    You could try Lionel Otto Instruments 124 Evans Rd Salisbury , Brisbane 07 32773888. The guy there is a Land Rover guy. They use small diametre copper tubing for oil lines & vacume lines . If he doesn't have any he may know were you can buy it.
    I also see some on ebay under toys games & steam. Also listed as refrigeration tubing. You to make sure it is soft copper tubing so you can bend it with out it kinking
    Aug 2011
    Albany WA
    Reece plumbing had some here in Albany, also try Heatcraft and Actrol refrigeration wholesalers.
    Cheers Steve
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by 1950landy View Post
    Hello 1950 Landy,
    Wow Lionel Otto Instruments are still around! I had a Smith temperature gauge rebuilt by them for my EH Holden back in the mid 1980s. It was ironic back then too - my first name is Lionel and the road they are on is my surname! It made the name of the company and their location an easy one to remember.
    There used to be a VDO-based instrument repairer here in Bundaberg - however, they closed shop years ago.
    Kind Regards
    Lionel
