Results 1 to 10 of 27
Thread: Weak Td5
    Dec 2015
    Sweden
    Weak Td5
    Hello down under!
    I’m a swedish LR owner having performance issues with my Disco II Td5 -99, 240 000km:s. A bit of a long story but here it goes:
    A few years ago the automatic gearbox was repaired by an experienced and well reviewed gearbox workshop. Everything was fine for about a year, then I noticed performance problems. Low speeds no problem, but impossible to maintain speed at even small hills, going down from 100 km/h to 70 making lines behind me and annoying other drivers. I suspected the gearbox again because of similar behavior before the previous box gave up, went to the gearbox workshop and was told there was only 6 months warranty on rebuilds but they took it for a spin and told me it was not the gearbox that was the problem. On a weekend I took a trip with the caravan and It was not a good experience. Had to abort as I had troubles getting up to speed, more than 70 Km/h was almost impossible.
    So: I did the stall test and the gearbox instantly gave up, and so did I. Put the car in a garage for two years until I had gathered enough guts to do a gearbox change on my own. Bought a rebuilt one from Ashcroft with heavy duty converter. Spent a big and exhausting part of my time under the car, and while the box was away I also did some other maintainance. The new box wasn’t performing very well, rough gear changes mostly, a gearbox ECU replacement fixed that. Still not performing so I checked the oil level in the box and could fill almost two liters! A broken connection on the oil cooler was the reason, maybe the reason for the first two boxes gave up as well… After oil cooler exchange and oil fill the gearbox worked as it should, but still very bad engine performance. I have done most of the fixes for this problem but nothing gives me the performance expected. Uphills, even normal hills on the highway slows down badly. Pressing the pedal revs up the engine but no result on speed, just more revs. Fuel consumption is normal. No sign of diesel leaking from the injectors(oil level slowly decreasing as expected). Starts flawlessly, even running. No black smoke, no smoke at all really and normal CO2 at yearly checkups.
    So far these fixes are done:
    New fuel pressure regulator (x2, last time including the filter)
    New MAF sensor
    EGR blanking
    Silicone hoses
    Changed the injector harness (Yes, it was leaking oil badly so I also opened the ECU but nothing inside)
    New waste gate regulator (x2)
    New diesel pump
    New air filter
    Driving without mufflers make no difference
    I have no errors on Nanocom
    Links to Nanocom log files if anyone interested:
    Engine: https://app.box.com/s/r3q3js3r9z184u95eup17lzuq0fui9dv
    Gearbox general: https://app.box.com/s/1dzgjif58t0pq0rw3hgc1cm4629adhad
    Gearbox pressures: https://app.box.com/s/dlvzarrs0j4v8h9wxy1l3pomwj3b0h9h
    Can anyone explain why all pressures except ”3-4 speed range 1” are at zero?
    Are the accelerator voltages ok?
    What have I missed? Please give me some advice. I was planning to keep this car for life, so I won’t give up.
    Oct 2007
    Brisbane West
    Hi mate. Can't help with TD5 issues but good to have you on board. You will find plenty of guys will offer assistance soon. Cheers
    Mar 2015
    Horsham Victoria
    Turbo related possibly
    Dec 2015
    Sweden
    Quote Originally Posted by RobMichelle View Post
    Yes, it sure could be, but nanocom log shows normal pressures if I'm not wrong. I can be going at 100km/h in lockup and when I get to a small hill it immediately gears down spinning the engine at +3000rpm, is that normal? Today I found that the wastegate lever was stuck and thought for a while I had found the problem, but no big difference after fixing it.
    Jul 2017
    Victoria
    Try to check that the boost solenoid or by pass it all together, what brand was the fuel pump? Don't use anything but VDO as the cheaper ones pack up quicker,
    Engine wiring not damaged or chaffing, maybe need to try another ecu, make sure the FRP filter isn't blocked even if it's new, check and clean it
    There are some ideas, I am not expect but have to start somewhere
    Crafers West South Australia
    Not a TD5 expert but if it was mine I would check the camshaft timing, injector clearances and use a mechanical pressure gauge to confirm the boost pressure.
    Jul 2014
    west of Transylvania
    Hi, according to the ECM data log it's not a management issue, the values are all OK so it can be fuel supply related, you said: New fuel pressure regulator (x2, last time including the filter)" , do you mean the small filter under the FPR or the main fuel filter cos you didnt say anything about that ... i know nothing about autobox correct data
    BTW... what size are the tyres? ...cos if they are bigger than std and no remap an auto will behave just like you said without having any issue, better get a remap, untill then replace the depression control valve(LLN100140L) if you know it's old
    NSW far north coast
    Quote Originally Posted by persod View Post
    Maybe the trans is stuck in Sport mode?
    In normal mode it'll hang in and use the engines torque, in Sport mode it kicks down almost straight away when you use a bit of extra throttle.
    Nov 2014
    Nirvana near Albany W.A.
    yes, data logs look normal, I'd also be looking at lack of fuel as none of your logs show anything above 3000 rpm , does it not make any power above this ?, this can mean second stage in fuel pump not working ( has been asked before but is it VDO), injector bump clearances , blocked filters , the heavy duty torque converters don't work too well without a remap but I think you need to sort fuel first.
    Jan 2014
    Perth Western Australia
    *Remove the air intake tube that connects to the turbo and put ur fingers in and see if the turbo fins spin freely, obviously with engine NOT running.
    *Disconnect the waste gate actuator rod off the spindle on the exhaust manifold and see if the waste gate opens and shuts freely, if not lube with something like Lanolin spray and open/shut open/shut until it is free.
    *As already noted, disconnect turbo modulator and run a line straight from inter-cooler pipe to turbo waste gate actuator.
    Daz
