Results 1 to 10 of 14
Thread: Series 16 gallon tanks
    May 2014
    Hi
    Do any of the knowledgeable people on here know were you can get the the 16 gallon fuel tanks from now all the usual suppliers don’t list them mine has completely rusted out thanks in advance
    1960 series 2 143001010
    1976 series 3 91331709c
    06 discovery v6
    2014 discovery tdv6
    2010 cub supamatic drover
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Wow, thats an original land rover one too. U can get one made up. At least they are easy to do.
    Narre Warren South
    The usual suspects get them made, not quite the same as the one in your photo but close......
    A sheetmetal fabricator could make one using yours as an example.
    Here's an aftermarket one
    DSCN2144 by Colin Radley, on Flickr
    Thicker steel, no separate cradle underneath (mountings welded direct to tank), drain plug was in the rear (good idea).
    No ribs pressed in the sides but if you look carefully there are two diagonal creases instead, this gives the sides a bit more rigidity.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2014
    Quote Originally Posted by gromit View Post
    Colin
    Thanks Colin do you know where you can buy the aftermarket tank
    06 discovery v6
    2014 discovery tdv6
    Narre Warren South
    Quote Originally Posted by Dgd69 View Post
    Four Wheel Drives over in Melbourne used to get them made and I'm sure all the other usual LR suppliers would have them or could get them.
    Just looked in a Four Wheel Drives old catalogue and they were $470 way back.......possibly best to look for a fabricator who could make a copy of yours.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Oct 2014
    Northern NSW.Australia
    My 'old school' radiator shop is fixing up my 10gal tank
    I separated it from its bracket.
    Just going to fix it back in with a few blobs of this, leaving an air gap at the bottom.
    Sikaflex Adhesive - 227, 310mL - Supercheap Auto
    whitehillbilly
    May 2014
    Quote Originally Posted by whitehillbilly64 View Post
    whitehillbilly
    Yeah my Boily mate going to have a look at mine but it’s a fair few holes needs new bottom of the tank and mounting plate as well
    06 discovery v6
    2014 discovery tdv6
    Oct 2014
    Mine held fuel, no leaks.
    Took it in to get checked, and when cleaned back lots of holes appeared.
    Not sure but think the holes will be soldered, then plate brassed over the top.
    Bob did my Fergy tank 12years ago. No leaks.
    Whitehillbilly
    May 2008
    Bundaberg Qld
    whitehillbilly
    Local "old school" radiator guy used this rusty 1926 Douglas (?) tank made a new one from scratch.
    He has repaired quite a few petrol tanks including Landy ones..
    whitehillbilly
    Do not leave an airgap - it will fill with mud and rust out the tank.
