Results 1 to 10 of 24
Thread: Air filter
    Mar 2015
    Horsham Victoria
    Air filter
    Should the air filter get wet with a snorkel fitted?
    Whilst changing air filter noticed it was slightly damp and could tell it had been wet at some stage, is this normal with snorkel.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    One wouldnt think so. Watching
    Nov 2014
    Nirvana near Albany W.A.
    Some can get through driving in heavy rain , especially if the drain ports on the head are blocked
    If it was after a creek crossing you have a leak
    Mar 2015
    Horsham Victoria
    No creek crossings in last 10 thousand unfortunately
    Jan 2017
    Geraldton WA
    The only way water can get into the air cleaner on a properly fitted snorkel is via the head of the snorkel so Rain is the obvious answer unless you have accidently given the air intake a squirt with the hose when washing the truck down.
    You can get those snorkel socks to fit over the head of the snorkel, these stop a lot of the rain, bugs and dust getting into the airbox.
    You can even use a normal sock impregnated with light oil and a couple of zip ties to do the job
    4.6m Quintrex boat
    Mar 2015
    Horsham Victoria
    Washing is as frequent as river crossings lol,
    Yeh I did use missuses stocking in Tassie when trees ripped head off snorkel, ok il get a spare filter.... Mario I'l send you an add on email
    Jan 2011
    Gippsland
    Quote Originally Posted by trout1105 View Post
    The only way water can get into the air cleaner on a properly fitted snorkel is via the head of the snorkel.......
    .......... Air filternot quite right! what about the airbox duckbill valve thingy that drains into the wheel arch. If its missing or damaged that’s a way for water from tyre spray to be drawn into the airbox. It happened on mine and i replaced it with a 38mm diameter rubber tube cap from the big red and green shed. Comes in a pack of 4 and i carry the remaining 3 as spares.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Jan 2017
    Geraldton WA
    Quote Originally Posted by onebob View Post
    When a snorkel is "Correctly" fitted that drain in the bottom of the airbox is sealed up and water cannot get in that way, As is the small webbing fitting that runs from the snorkel to the airbox
    Not much point in fitting a snorkel if there is a hole left in the system lower than the snorkel head.
    4.6m Quintrex boat
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I have had a couple of forum members having wet filters, but that was from driving in torrential rain with the snorkel inlet facing forward sucking it in.
    Jan 2011
    Gippsland
    Air filter
    All true of course trout1105 and the OP is advised to check that the snorkel is “correctly” installed.
    NB: in my case i got an airbox full of soupy mud during a 4x4 training course at Mt Cotterell near Melbourne (for those that know the place) and that spurred me on to install my snorkel Air filter
    LROCV member #131
