Results 1 to 3 of 3
Thread: AIR SUPPLY TO DISCO
    sav Guest
    AIR SUPPLY TO DISCO
    DISCO V8 96 MODEL, SEEMS TO BE LACKING POWER AND ECONOMY, WHEN I REMOVE FACTORY AIR FILTER, ALL PROBLEMS GO AWAY. IT IS A BRAND NEW FILTER SO WHATS WRONG?
    WOULD FITTING A SNORKEL FIX THE PROBLEM? OR IS IT JUST NOT RUNNING LEAN ENOUGH? IS IT A TUNING PROBLEM? OR IS SOMETHING WRONG WITH THE o2 SENSOR?
    ARE THERE ANY OTHER SENSOR'S THAT COULD BE PLAYING UP?
    tHANKS FOR ANY HELP.
    SAV
    Toowoomba QLD.
    Sounds like the MAF could be faulty. (Air Flow meter).
    Trev.
    Sav,
    Just a hint - turn Caps Lock off. It make posts hard to read and it is considered shouting. Regards
    Ron
