it does unclip easily, if I remember the clip is on the bottom, you may need a small screwdriver to release it. You can get some more space to see by removing the hazard switch first
Tote
I want to install a dash mounted reverse camera on my 110 ( 2015)
I have all the wiring in place from rear to front.
I now need to take out the front facia /radio/ control panel.
I have done this before but have never taken it fully out as I cannot figure out how to disconnect the clock . I have tried every thing ....squeezed it ...wiggled it pulled it .....to no avail ...just can’t figure it out
anyone who has removed this facia / clock connection have any idea how to do this ?
I would like to get the whole center facia/radio unit clear out so I can drill a hole for the dash mounted monitor wire
thanks a bunch .
Tote
Thanks . I manage to get the wiring done but with some difficulty
I couldn’t remove all the switches and left the facia dangeling by the clock connection as I could not figure out how to get it out
next time I’ll remove the hazard switch and poke it with a screwdriver as you suggest and see if I can get it to release ....all other switches easy ...just the clock seems different type of
connection
