Results 1 to 10 of 16
Thread: Spot Light Mounts
    Spot Light Mounts
    Anybody used one of these to mount 2 discrete spot lights (not light bar).
    LAND ROVER DISCOVERY 4 UNIVERSAL SPOT LIGHT BAR STAINLESS STEEL MOUNTING BRACKET
    Do you experience any bounce / vibration in the vertical plane when the lights are fitted?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Jan 2017
    Geraldton WA
    If you are handy with a welder and angle grinder you could knock something up out of scrap steel to do the job for a fraction if the $350 price tag
    4.6m Quintrex boat
    Dec 2009
    Ranelagh, Tasmania
    Difference is these are laser cut stainless steel.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Quote Originally Posted by trout1105 View Post
    Yes, I have done that but I am unhappy with the degree of vibration so was wondering if the $350 job was somehow magically better because it cost so much more.
    1984 RRC, in hell
    Jan 2017
    Geraldton WA
    Quote Originally Posted by Ferret View Post
    Upgrade the thickness of the steel or you can brace the mounts you have already made to get rid of the vibration as much as possible, Nothing will ever completely stop the spotties vibrating even when mounted to a bullbar.
    There is also No guarantee that the stainless mounts will be any better than what you have already fitted
    4.6m Quintrex boat
    Mar 2007
    South Arm, Tasmania
    Have seen a post on here previously by someone who has these fitted, but can't remember who it was.
    It is interesting that in the photos in that link, the Fyrlyts have "stabilizer" rods from the top of the light back through the grille. Someone must have drilled holes in the top of the Fyrlyt light bodies to allow for this, as there is no provision for stabilizer rods / brackets on these lights as standard. In fact, the Fyrlyt body / assembly is very light - much lighter than just about any other similar sized lights I have come across (this is one of their big advantages) and as such, when combined with their very robust solid billet mounting block, should not need stabilizer rods. Mine (mounted on the bullbar) certainly don't need any aid to hold them stable.
    Based on the above, I would suspect that if someone has seen the need to drill holes in and add stabilization rods to these lights on this type of bracket, then there must be a reasonable amount of flex / vibration in the brackets with large lights mounted to them.
    I had a heavy polished stainless steel nudge bar on my D2 when I bought it. I mounted a set of Hella Predators to that, and the vibration was so bloody annoying that I removed and sold the nudge bar and replaced with a new bullbar at Discovery Auto in Wangara. I personally believe that if you want to have just a light bracket on the front of the D4, you could make something at least as strong as and probably much stronger than the stainless brackets from Osborne Park for a bloody sight less than the $350 they're asking - but that's just my opinion.
    Cheers .........
    BMKAL
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by BMKal View Post
    Same here. I have a pair of Fyrlyts fitted to my bullbar and have never noticed any flicker.
    Martin
    Jan 2012
    I have one of these and get a reasonable amount of flex, far too much for the $350 i paid IMO.
    Geoff
    D4 TDV6 MY13 White - GONE
    Thanks very much for that. I thought that might be the case.
    I would imagine no matter how robust you make that style of mount, it can only be as stable to the thing you attach it to. In this case the ~ the 2mm steel (however thick it is) the radiator surrounding are made from.
    Seems LR make a driving light mounting kit.
    1984 RRC, in hell
    Aug 2017
    Western Australia
    I have looked into several options to fit additional lights to my D3 and I came across this option from Prospeed.
    Discovery 3&4 Front Spotlight Mounts : ProSpeed
