Hey Carlos,
For mine, I used angle grinder with wirebrush wheel and detail sander to remove loose paint, then phosphoric acid for any remaining surface rust. I did leave quite a bit of the original paint, but just smoothed it out with the detail sander, then sprayed the whole thing with etch primer.
If you're willing to strip all the old paint off, then go for it, I just didn't see the point to investing all that effort. To do that, I'd say you'd be pretty much using the same tools, angle grinder and detail sander.
Mine also had some accident damage which required cutting and welding to fix, but also a "twist" in the firewall, which I rectified by laying it on some strategically placed wooden blocks, then two people jumping up and down on it until the twist caused less than 5mm misalignment. I figure I can cater for the last bit of twist during installation.
Hope that helps.
