Thread: Accessing the battery
    Is it just me or is it overly difficult to access the battery?
    I assume there must be some special tool required to reach and operate the lock slider from the jack bay because with my largish hands it was a real struggle and the workshop manual is next to useless.
    Pennant Hills, Sydney
    Battery looks small? or you have big hands, mind you battery technology is improving after sitting stagnant for so long.
    Someone is now doing a second battery kit which I will look at for running dash cam and other items.
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Oct 2011
    Hunter Valley
    See a section of this youtube video, at 1m48s see Leigh's solution.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Dec 2011
    The small battery is only the stop start backup battery. Isn't the main battery under the spare wheel like in the L 494?
    Barry
    Feb 2013
    Wamuran, Qld
    Off topic, but what’s the little white funnel in the first pic for?
    Ron
    2013 D4 SDV6 SE
    Kilmore, VIC
    106.38 MB
    Filling adaptor to allow the use of a high flow diesel nozzle if you need to...
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    Feb 2013
    Wamuran, Qld
    Quote Originally Posted by DiscoClax View Post
    Thought something like that. Been caught before. Where do I get one?
    Ron
    2013 D4 SDV6 SE
    Kilmore, VIC
    106.38 MB
    Any dealer anywhere should have them (not just LR) or eBay et-al or just find a (fuel-resistant) funnel that has the correct vehicle-side diameter to fit into your opening and then cut it down for compactness (as desired) on the nozzle-side. If your vehicle has a cap-less setup then the funnel needs to be a very close match for a standard nozzle or it won't release and allow insertion. That's about the only trap.
    Something like this...
    GENUINE FORD EMERGENCY DIESEL FUEL FILLER FUNNEL / DIESEL ELBOW, 1782177,1833948 | eBay
    PETROL FUEL TANK FILLER FUNNEL OEM FOR FORD GALAXY MONDEO KUGA S-Max | eBay
    DiscoClax
    Feb 2013
    Wamuran, Qld
    Ta! $3.37 from EBay, postage free.
    Ron
    2013 D4 SDV6 SE
    NSW SW Slopes
    Is that one diesel or petrol neck size?
