I lined the interior of the Oka cabin with Dynamat about five years ago. The Oka has similar acoustics, or lack there of as the Defender, probably worse really as the Oka is a 'cab over' vehicle similar to a 110. It involved a fair bit of messing around but not terribly difficult. The main thing I learnt early on was to make sure the metal surfaces were clean and dust free to gain good adhesion and not to 'de sticky' the Dynamt.
I fitted a single layer to the floor and foot well sides and every other surface with a double layer to the engine sides, side covers and hatch. I covered it all with thin marine type carpet stuck on with contact adhesive. I also removed the internal door covers and covered the insides of the doors outer skin as well.
The result was remarkable. I don't know much about low freq vs hight freq, percentage coverage or any other technical stuff but I do know that I can now listen to the radio, CB etc without having the sound levels up high. I can converse with SWMBO without shouting and use the mobile phone, err ....... the passenger can use the mobile phone whilst on the go
. Traveling is much more pleasant and comfortable.
It cost me around $600 at the time and was worth every penny and hour spent. Lining the inside of the doors made a significant difference to the overall outcome and is IMO definitely worth doing.
Deano
66 SIIA SWB .......73 SIII LWB diesel wgn
86 RR 'classic'......99 Range Rover P38a
94 Defender 110..95 Defender 130 Ute
96 D1 300TDi.......99 D2 TD5 (current)
04 D2a Td5..........02 Disco 2 V8
