Yep I want one too!
I would like to make one of these out of my D1 but I am anticipating it would fall foul of ADRs
There are heaps of fairly cheap D1s available and rebuildable, and parts are plentiful.
Yep I want one too!
My third 98 D1 300tdi Auto -now registered
81 Rover SD1 manual - long term project
That’d be a good rig.
Mom sure if you check out their website, it’ll give you some info on how they stack up, and then you can compare and check on the Aust rules and Rey’s to see how hard it would be.
A great idea anyway if you’ve got land and are in need of a Ute.
Yes please! That would make an awesome farm truck.
Life is just a series of obstacles preventing you from taking a nap.
May as well do a coil spring conversion on a 101 Landrover.
Note the rear tray doesn't have the rear wheel wells going into the load space.
It lacks rear wheel travel...….the front looks OK.
Even a defender HCPU has the rear wheel wells into the load space, or you end up with a very high tray or no rear wheel upwards travel
They do a dual cab and bus body too.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Here is the link
Welcome - Rotodama - Recycle your Discovery
YES PLEASE!
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
