Results 1 to 6 of 6
Thread: PTO
    Unison Guest
    PTO
    Can anyone tell me if you can fit a 6x6 pto to a 4x4 perentie? I believe both variants use the LT95 box but may have slight variations.
    Queensland
    No problem.
    Just have to change the input gear in the top PTO hole for the one with the sprocket that chain drives the bottom PTO.
    Do you have one?
    I have a spare here I dont need.
    Hay Point
    Quote Originally Posted by Unison View Post
    It will bolt straight on but the difference between the two is the torque limiter. It is loaded higher for the weight of the 6x6. But you can still use it as is as long as you are aware of the winch limitations. If you want to adjust it all you have to do is remove 4 balls and springs from inside the torque limiter assembly. The 4x4 has 8 and the 6x6 uses 12. Your 4x4 Perentie will have the correct gear already on the rear of the mainshaft.
    Cheers......Brian
    1985 110 V8 County
    Unison Guest
    Pto
    Thank you both for your reply. Unfortunately I missed out on the pto at the auction. (went for $19 too) so no longer need parts etc. Wanted to build up a pto driven winch but possibly too hard to source rest of parts. Anyhow plenty of other jobs to be completed.
    Quote Originally Posted by 123rover50 View Post
    No problem.
    Do you have one?
    Queensland
    It is a complete PTO I have. Worth more than $19 though.
    australia
    hi can you send me photo and price regards jim
    Russell Rovers
    Series I Parts Specialists
    russellrovers AT gmail.com
    Phone 0428732001
