Thread: Front axle seal - how important is it to have this seal sealing well ?
    Jul 2016
    Hi All,
    I noticed the seal face on my half shafts are not the best, they're not totally stuff, just not looking brand new. So I am contemplating whether or not I should replace them. But then I thought, how important is it that the seal seals well anyway ? Is there are great fear of diff oii getting into the swivels or vice versa ?
    Of course I could just smooth them down a bit with some 1200.
    Any advice welcome.
    Not a significant problem - just keep an eye on levels.
    Jul 2016
    Thanks for confirming John, I was thinking is wouldn't be a big issue.
    Narre Warren South
    Not expensive to buy, if you are removing the inner bearing race you could remove the collars and clean them up in a lathe.
    Spacer - Paddock Spares
    As John said.......if the surface is likely to damage the seal then regular checks to make sure the oil hasn't migrated.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2016
    Ha, I just has one inner race replaced not realising that the seal "race" could also do with replacing - Doh !!
    I order a couple of the seal "races" now, see how the timing of it all goes.
