Results 1 to 10 of 11
Thread: Maggie - 1960, 88, farm truck. Anyone know of a good Series specialist in Adelaide
    Feb 2018
    Adelaide
    G'day all,
    I'm currently restoring my 88 to work on the farm (read: not a bush basher, but more akin to a quad bike ) she will herd cattle, drag apple trailers around and the like. I am in the midst of ripping down her engine, and have been thwarted in changing the rings by a lip on the bore.
    Does anyone know of a good machine shop in / around Adelaide ?
    Are there any telltale signs of knowing if the crankshaft bearing are oversized ?
    Kim
    Narre Warren South
    Quote Originally Posted by Kimsl70 View Post
    If you pop the shell bearings out the size will be stamped on the back.
    You used to be able to get a 'ridge remover' for removing the lip at the top of the bore. Not ideal because the clearance between the piston & bore is increased due to wear but with a new set of rings could get you by for your planned use.
    I hand scraped the wear ridges in a 6-cylinder motor but checked the bore top & bottom to determine the amount of wear.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Hobart Tasmania
    Kim is that you from instagram maggiethelandrover?
    Carlos
    1963 Land Rover Series 2a 88
    Sep 2012
    Westlake ,brisbane
    If you are not doing a rebore you need to remove the ridge other wise you could brake the top ring wten the piston comes to TDC when running.
    Feb 2018
    Adelaide
    Hi
    Quote Originally Posted by Cap View Post
    G'day Carlos, yep this is me, one in the same. How's it going ?
    Feb 2018
    Adelaide
    Quote Originally Posted by gromit View Post
    Colin
    Thank you, I appreciate the reply, I'll have a look at the shell bearings. They don't seem to have anything marked on them but do have some stamping on them. For the life of me, I cannot find a decode on these anywhere.
    Hobart Tasmania
    All good here mate! You're in good hands on AULRO - lots of experienced owners on here.
    Carlos
    May 2014
    Are they the early small bearings only used on first series2 2 1/4 engines from 58/61 engine number starting with 151xxxxxxx could be the original ones fitted
    1960 series 2 143001010
    1976 series 3 91331709c
    06 discovery v6
    2014 discovery tdv6
    2010 cub supamatic drover
    Feb 2018
    Adelaide
    Quote Originally Posted by Dgd69 View Post
    I think you've hit the nail on the head. The engine number is 15100139, so that may answer that question. I've purchased a micrometer today and I'll have a look at tolerances. Thanks for taking the time to reply, and the headsup, I really appreciate it.
    Feb 2018
    Adelaide
    Cheers mate, so far they've been exceptionally welcoming and helpful.
