Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Toyota Hi-lux engine fault
    May 2010
    brighton, brisbane
    Last edited by Mick_Marsh; 7th July 2018 at 06:17 AM. Reason: to be moved to asian manufactured
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Jan 2017
    Geraldton WA
    See what happens when car makers stuff about with a perfectly good design just to make them more high tech
    I have owned several Hilux 4WD's ranging from the original model to a 2004 model and these were pretty much Unbreakable and they certainly didnt have an easy life either
    4.6m Quintrex boat
    DAMINK Guest
    Quote Originally Posted by trout1105 View Post
    Agree a few mates have them. Locked and loaded. They are pretty impressive vehicles. Pretty much unbreakable i agree.
    Aug 2010
    Sunbury, VIC
    So, don't drive your Hilux through dusty areas and don't drive your Ranger through tall dry grass - got it, don't take them where they were supposed to be designed to go...
    St Helena,Melbourne
    4.28 MB
    Does a hilux have any power to lose ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2010
    Sunbury, VIC
    The 2.8 in the current models is a very good engine IMO, and well matched to the 6 speed auto behind it - done over 100,000KM in 2 years in mine now with heaps of towing involved - easily handles 2 tonne trailers with no fuss, I do tow a 3000Kg genset behind quite a bit too and it sure notices that, but I don't travel faster than 80 with that on (company policy) and it just makes sense even though it tows fine. I doubt there are too many vehicles in thisnsize range that wouldn't feel 3 tonne hanging off the back to be honest.
    Without a load it's actually quite nippy and maybe it easily does 150 but I can't comfim that personally... 😉😇
    We all like to bag out Toyotas (I sure do) but I may well buy this vehicle when it comes out of lease if it continues as it has done (still 2 years to go so a big if). I like my Hilux. 😊
    Jun 2013
    Quote Originally Posted by DAMINK View Post
    I had a 2001 model dual cab hilux that I bought new in Malaysia (before I bought my current dual cab defender new in 2013). Definitely was NOT unbreakable.
    - in the first year I took it easy on it under warranty. No mods, and "offroad" would have been defined as shopping centre carparks and mild dirt tracks on building construction sites.
    - "Articulation" it was subjected to would have been defined as crawling one wheel at a time over kerbing to get "offroad" as that term is described above
    In the first 3 months of its life (whilst taking it easy as defined above) the rear leaf spring packs got a bit twisted. (Must have been the "articulation" the vehicle had been subjected to as above.)
    - mention it to Toyota at service time, wanted it fixed under warranty.
    - "has the vehicle been used offroad?", asks they
    - "yes", says I
    - "ok... not covered under warranty", says they.
    - 6 mths of argument later they offered to pay half the cost of parts and replacement
    - "no thank you", says I. I decide the warranty is worthless, so no harm in wholesale upgrades. Replaced all suspension, had the fuel pump tweaked, and fitted all manner of bars and winch etc.
    Wanted a reliable vehicle because of my penchant for going deep into Malaysian rainforests for fun weekend and week long trips.
    After breaking 4 CV joints on successive trips and (at the time) no HD items to be had for love nor money - decided to offload the vehicle.
    Notes:
    - I should have researched better. Turns out all hilux drivers at the time knew of weak CVs and wheelbearings that can't handle even 32" tyres for long.
    - I attribute the Hilux CV and wheelbearing fails to them being plain and simply weak.
    - My Hilux had the rather horsepower deficient 2.8l NA diesel engine. So even exhuberant throttle application could only result in an asthmatic wheeze of power.
    - And none of the breakages were due to the way the vehicle was driven at the time. (e.g. no wild wheelspin breaking things when the wheel touches down - all knew that breaks axles, so can't do that)
    - After the first two CV breakages I resorted to extended steering stops, enduring a Defender-esq turning circle equating to two postcodes - in a useless attempt to avoid the next two CV breakages.
    Not that its relevant to hiluxes being unbreakable but:
    - it has to be noted that much later, in 2013, I bought a new Defender. (because I had been advised Hilux CVs and wheelbearings were no better than before)
    - in the 3.5 yrs before I brought said Defender with me to Oz I took it in and out of the same Malaysian rainforests that I had taken the hilux
    - I can attest to having had NO breakdowns in or out of the Malaysian rainforests or urban jungles
    - [edit] nor any breakdowns in the 1.5yrs the vehicle has been in Oz.
    Neil
    (Really shouldn't be a...) Grumpy old fart!
    MY2025.5 110 D250 S MHEV (L663)
    In Memoriam:
    MY2013 110 TDCi DCPU purchased new from Land Rover Malaysia in May 2013.
    ...traded in for the above L663 in December 2025.
    Nulla tenaci invia est via
    May 2010
    brighton, brisbane
    So, what chance the new defender is a dud?
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by bob10 View Post
    If you're looking for a rugged, utilitarian go anywhere no fuss vehicle, it will be 100% dud from your eyes. If you're after a luxo barge to drive around town in that looks like every other new Land Rover but with a Defender badge on it, then it will probably be fine.
    Jun 2013
    Plenty of other threads on here for that discussion
    Neil
    In Memoriam:
