 Originally Posted by
lowy
				Hi all ........
Im thinking about buying a 94 or 95 defender flat tray , It's cheap so I'm buying it for the roof and back panel for the perentie .
I have a few questions tho , I assume that year has rear disk brakes ? Will they fit straight onto the perentie ?
Also, Is the front diff/axle housing the same as the perentie ...or at least will it be a straight swap over , Keeping my Ashcroft axles , stub axle and aeu2522 cv joints  etc. ?
I assume drive shafts are different ?
Do they have belt drive power steering ?
Any idea what gearbox / transfer these have
thanks all
Luke
 Hi Luke,  The defender rear disc brakes if fitted to the one you have are a different design to the perentie ones but they will physically bolt on if you change the complete axle. The front diff has the same housing but I would be unbolting your one at the flange and putting the stronger county/perentie swivel housings on with the heavier internals. It would have either an lt77/lt230 or an r380/lt230. I think the driveshafts would have small differences in length but probably someone like JC could confirm that plus the PS query.
				Cheers......Brian
1985 110 V8 County
