Thread: Replacing ball joints and steering joints
    Pennant Hills, Sydney
    Having fun replacing ball joints and all steering joints, makes it easy when you have the right tools, those ball joints took a bit to get moving.
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    Feb 2017
    Deception Bay, Qld
    You have the right size hammer for the job, 2 x4 pounders are even better.
    I like your stands do the tops screw out also.
    Apr 2018
    Bendigo
    Hey Stevo, which adaptors did you use with the OTC press thingy? I have one that I bought for my Jeep and I have the standard adaptors and the Jeep specific ones.
    Yes the jacks also screw out, not a great amount though.
    the press just had generic parts in it which did the job, if I was doing a lot of these there would be a mod done to one of the adapters.
    May 2003
    On The Road
    Nice braided lines, nice jacks, nice Billies,,
    Nov 2015
    Merbein
    35.44 MB
    I did one side the other weekend, took 9 hrs, similar tool but none of the adapter tubes fitted properly and ended up using sockets and bits of pipe. They fought all the way, breaker bar with a length of pipe added and lots of grunting and groaning. Will make up specific adapter tubes before i tackle the other side.
    PeterN
    70' 164 Manual Volvo 227,000miles play car. "Sven"
    2001 BMW R1150RT bike, 118,000Km "Bruce"
    2000 D2 TD5 Auto 329,500Km and climbing. "Leaky" (VK3JUG)
    2024 Dualcab Hilux work truck, 12,000Km.
    Sharp eyes
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Those braided lines are they Terrafirma ones. i notice you have them fitted with a Yellow cable tie. If so is that because the retaining part of the hose falls thru the vehicle brake hose retaining bracket? The Fitting on the hose is too small to securely fit and passes thru the front bracket hole..
    The reason i ask as i have a customer who has Terrafirmas hoses on his D2 and you cant fit the retaining clip.
    The cable tie was put in because when I had done the lines I lost the clip, the clip is on the other side and I should get one to fit that side. Has been like that for a few years now
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by stevo View Post
    Ok were they terra firma ones?, as i have a complaint of a set that they go thru the braket hole so you cant put a clip on, just wondering about yours.
    Cheers, Mario
