Originally Posted by
wbowner
Ron
The green cart light does not come on when indicating right only left.
If I remember rightly, I think this is by design to indicate you have a blown light on the trailer (the old globes). Given you have LEDs it would indicate a wiring issue on the right circuit.
Get a volt meter and trace the issue. Have you tried the trailer on another car?
wbowner
....when van attached no right indicator light ....
By this I assume you mean the trailer has no right blinker, while the D4 does.
BTW (I'm sure you know this) the D4 does not need the linear electronics box, all that is required is a couple of resistors in parallel with the trailer blinkers - you only need one but for the price, I would do one on each blinker. So if its the box then you have a cheap fix.
Sean
