Thread: Front axle assembly alert
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Just as a caution for all Series owners!
    This morning, I noted some fresh oil under the 2a. Nothing unusual yoou say? But this was not from any of the usual locations.
    Two minutes was enough to see that the oil was coming from the join between the RH steering ball and the front axle housing. Another couple of minutes showed that at least some of the bolts were loose.
    It took quite a bit longer to jack that side front up, remove the wheel, and remove the bolts one at a time, degrease them and refit them with some loktite as well as the non-plastic self locking nuts, adjusting the grip of the nuts as necessary. As those who have been there will know, you cannot get a ring or socket spanner on any of the heads of the bolts, and only on a couple of the nuts. So using open end spanners, it took a long time.
    It is probably twenty years since these bolts have been loosened (last time I replaced the swivel seals), so I have no idea what allowed them to come loose. Obviously I checked the other side, it was tight.
    Rather to my surprise, the bolts are BSF - I would have thought that for the 1970 model they would have been UNF. But, of course, the front axle may have been transferred from an earlier model in service.
    I had, when driving back from town on Tuesday, noted that I had developed a slight shimmy after hitting bumps, and decided I needed to check the swivel preload, but I have no doubt that this problem was in fact the cause.
    So, word of caution - look for bolts that have shown signs of movement every service, and investigate unexpected oil leaks!
    in the wild New England, NSW
    Timely reminder JD, thanks
    Jul 2011
    Yarrawonga, Vic
    Funny you should bring this up.
    Im building up a 10 Spline trueurac for the front of my '73 Lightweight & I discover I have 3/8 BSF instead of the usual UNF holding my crown wheel in . As Im fitting a Metric Trueurac carrier into an Imperial housing I am using an Ashcroft spacer so need 10 x longer BSF bolts.
    Lo & Behold last night I see my Swivel Ball bolts are also 3/8 BSF & are the correct length for my Crownwheel & spacer . So I'll be doing the old bolt switcheroo trick.
    JDNSW's Avatar
    Interestingly, I just had a look at the parts books - not only do all S2a have BSF, but all S3 do as well. Which surprises me - I thought that they had gone to UNF by then except for threads tapped in to parts (i.e. not bolts and nuts). I wonder why they did not change?
    As far as I can see UNF bolts would have been just as strong. I suppose UNF nuts would have to be a little deeper, and there is limited room. Also, UNF heads and nuts are a little smaller, so may have required washers, both meaning a longer bolt which could make getting the bolts in pretty hard due to the ball, especially for the one holding the steering stop, which is 1/8" longer anyway.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yeah, when doing these on my series 3 a little while ago I learned they were BSF which I wondered at the time if earlier parts had been fitted at some point, but my parts supplier put me straight on it. A bit strange that's for sure, but I suppose 'If it ain't broke, don't fix it' could apply here.
