I am assuming it's the same type of filter , small round one basically under the drivers seat but underneath the car .
could be the O-ring at the top not seated properly, could be the old one stayed on the nipple when you removed the old filter , they also leak on the bottom oring where the water sensor screws in.
from what I have seen of those quick release fuel fittings is they seem pretty robust and unless you have somehow disturbed 1 I would be surprised if they are leaking .
Cheers Ean
