Thread: Glue for D3 External Door Handle Cover
    Mar 2012
    Armstrong Creek, Qld
    The front, external, passenger side plastic door handle cover has come off the D3. Is "Superglue" good to use or is there an automotive glue better for the purpose?
    Steve
    St Helena,Melbourne
    1.13 MB
    I'd use one of the loctite products, 401 or 406 i think it is.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Is that the bit that covers the key lock? It is designed to fold back to access the lock - if you glue it on you will not be able to open the door.
    Disregard if it is not this bit.
    Oct 2011
    Hunter Valley
    That was the first thought that came into my mind when I read the post
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Mar 2012
    No, fellas It's the main handle cover.
    Oct 2011
    Hunter Valley
    I guess superglue would do the job. Or was it stuck on with 3M double sided tape before?
    IIDTool BT
    Mar 2012
    Thanks mate. Loctite worked a treat.
