1st April 2006, 11:10 AM
ABS pump keeps running
Discovery series 1 94, The ABS pump keeps running,even when i start the car I have never heard the pump running until this morning.Then when i shut the car down the pump keeps running,making a vibrating sound.
The only way i could shut it down was to remove the fusable link.
Anyone got any ideas what could be causing this?
p.s. its been raining this morning and only started after i went out.
EDIT*is it safe for me to use my car if the fuse for the ABS is removed?
1st April 2006, 04:35 PM
Me thinks me fixed it.
Can someone tell me for sure tho. Is the senser on top of the brake fluid cap could have anything to do with it?
I gave it a clean out and it worked after that :?
Anyway its all ok now
1st April 2006, 10:08 PM
<span style="color:brown">sounds to me like a relay may have been stuck on.....
pulling the fuse out may have reset the relay...for now....
if it was a relay....it will probably happen again.....</span>
1st April 2006, 10:52 PM
#4
if it is a relay how do i know which relay is which as they are all in the same area?
ideally i need a workshop manual
1st April 2006, 10:54 PM
#5
<span style="color:blue">the relays should be labelled just like the fuses are on the fuse box cover...</span>
3rd April 2006, 11:14 AM
#6
I had a look and they are all the same in colour and numbers :?
I should be looking under the glove box area ,right?
3rd April 2006, 11:32 AM
#7
There are three relays together.
I think from reading an article long ago that they are under the bonnet but I could be wrong.
Anyway they are all just $10-15 relays so replace the lot.
apparently they do not warrant new ABS pumps unless you replace the relays so its a common problem.
Regards Philip A
3rd April 2006, 11:43 AM
#8
Thanks mate
