Results 1 to 10 of 21
Thread: Not stress testing a PC--
    May 2003
    On The Road
    I have just built a PC for a friend, he understands the "limitations" offered,,
    all I need is a test/benchmark that runs for a long time but isnt out to break the components,,
    there are lots of cpu tests
    and lots of vid card tests
    and memtest
    but I'm not really interested in max testing,, ( though I had to run memtest 27 times to work out a problem...)
    the system is not set up for Heaven, or Furmark..
    really all I need is someone to sit here and work this for a few hours,,,
    and thats the test I need...
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Victoria i think it is called on hirens...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    Oct 2003
    Montrose, Vic.
    I thought you had a natural talent to stress PC's Pedro....
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    May 2003
    On The Road
    Ok,, last job after ensuring it all worked was to check cpu paste,,
    and found this,, and its stuck hard!! small screwdriver wont lever it off (gently)...
    has not looked like over heating,,
    May 2003
    On The Road
    Quote Originally Posted by Bytemrk View Post
    Not Natural at all ,, I've had to spend a lot of money to achieve this level of mechanical stress!!
    May 2003
    On The Road
    Oh,, and I couldnt find victoria on the latest Hirens(this year!)
    May 2003
    On The Road
    so,, do I lever the cpu off?
    or try and reseat the cpu AND Cooler onto the motherboard?
    atm no pins are bent,,,
    and yes that means I pulled the cooler AND cpu off the socket
    May 2003
    On The Road
    just tried a twist test on the cpu and its not budging!!!
    May 2003
    On The Road
    But. but but but.....
    to reseat the cpu I have to lift up the pressure lever,, which of couse interferes with me reseating the combo...
    I am actually concerned now the amount of force required to remove the cpu will **** it...
    whatever thermal compound they used was more glue than thermal!!
    thinking 12" multigrips and twist.. more area to grip
    and yes I said multigrips.....
