Thread: tdi 300
    tdi 300
    HI ALL.
    WHAT SORT OF KMS COULD I EXPECT FROM A 300TDI BEFORE A REBUILD.
    REGARDS SUMO
    Apr 2002
    Bellara 4507
    32.43 MB
    300,000 + is quite common, depending on how well it was maintained.
    i know of several with 400,000-500,000 on them that havent had a spanner put to them. mine has 210,000 on it and it still pulls like a bullock...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Newcastle
    caps LOCK 'MATE!!! we are all friends, no need to yell
    300 thou should be good, more or less depending on how well u treat her
    Adelaide Hills - SA
    If they lose coolant, they can easily overheat and crack the head (or was it just the head gasket that went - I can't remember).
    That's the only problem I've had with mine in 10 years. Should have taken action when a few spots of coolant showed up on the driveway, but I ignored it for a week or two and then it was too late. No warning on the Temp gauge either.
    They are an excellent motor.
    Spudboy.
    Evidently they can spring a leak behind that front auxillary housing where the water jacket is , the orignal gasket was a bit sus, so Ive been told. Have a 130 trayback 1996 model, not to many probs so far use it everyday for work. Love driving it , even though they are a bit squeezy.
