Results 1 to 10 of 16
Thread: PTO winch
    lowy Guest
    PTO winch
    I lost the slip yoke , end yoke and uni joint from the winch the other day , Thankfully , just after it saved me with a long winch up a hill after blowing the front diff .
    Anyway replacements ordered , keyway ordered , It just got me thinking .......How often will these keyways fail ? , should I carry a spare , I assume they fail before a Brocken shaft or uni joint ? ,
    Can someone with some experience with these winches tell me what I should carry , did I loose the slip/end yoke because of a Brocken uni and no grub screw in the end yoke do you think ?
    Thanks all
    Luke
    Feb 2005
    Umm, being a perentie the key shouldn’t fail (it’s not a shear key or pin in the case for my PTO), the UJ might have failed which than damaged the key.
    The perenties have a torque limiter incorporated in the PTO drive, when you load the PTO up too much the torque limiter should disengage drive to the winch protect the winch components.
    I vaguely remember it’s spring pressure on ball bearing that the the max. torque.
    If your shearing Keys than you have other problems.
    in the wild New England, NSW
    I guess that the torque limiting clutch mechanism could fail to slip for all sorts of reasons including debris ingestion & lack of maintenance.
    See Para 242 on pages 64/65 in https://afmsafety.com.au/wp-content/...-661284221.pdf
    Melrose SA
    Quote Originally Posted by lowy View Post
    Crappy day eh?
    lowy Guest
    Quote Originally Posted by djam1 View Post
    Crappy day eh?
    It was a long day ,Had to winch up a long hill around corners , then needed to remove both axles , Because the front diff was binding badly , I had nowhere to remove them until I reached the top .......
    It got me home tho ...so could of been worse .
    I don't think I broke a key , more just lost it when the end yoke came off .
    If they don't fail ....I may of over purchased PTO winch
    Thanks everyone .
    PS ....if you need some keyway steel for a PTO winch
    PTO winch
    Hay Point
    Thanks all
    Luke
    Luke there is no way that yoke can come off unless the grub screw was loose and then allowed the uni joint and slip joint to move back on the rear shaft and fall of the middle shaft. Just fix it up and loctite the grub screw with a medium strength loctite. You don't need to carry spares for these winches.
    Cheers......Brian
    1985 110 V8 County
    Jan 2012
    Yanchep Western Australia
    Quote Originally Posted by Bearman View Post
    Same thing happened to mine too. I did what Bearman suggested. No problems since. link below to thread below.
    Winch PTO Uni Joint Gone Missing
    Regards Warrick.
    "Any intelligent fool can make things bigger and more complex....It takes a touch of genius and a lot of courage to move in the opposite direction."
    Albert Einstein.
    lowy Guest
    Good to know , thanks for that , I better make sure the others have some loctite at the same time.
    lowy Guest
    Quote Originally Posted by wpalmo View Post
    Regards Warrick.
    Thanks Warrick ,
    That's where I got the part numbers from ,
    I just wasn't sure if any of these parts where easily damaged .
    My mind has been put to rest
    Thanks again everyone .
    Queensland
    While you are talking PTO,s
    Can the bottom PTO be reversed to drive to the rear instead of the front?
