Results 1 to 9 of 9
Thread: Timing Belt
    Timing Belt
    As part of all that other stuff that we won't talk about I also had the timing belt done on the 300tdi.
    Sam gave me a whole boxful of exciting stuff, including the old timing belt.
    I'm happy either way, peace of mind is what matters, and when everything else was out, doing the timing belt was a drop in the ocean.
    But, I thought I'd take a few pix and let you folks tell me how stuffed or unstuffed it was. Turns out the photos were much harder to take than I thought. The belt had threads coming off on one side and the teeth were starting to look a bit scuffed and mildly chewed on the outer edges - from the LR, not from the test team.
    Simon
    Jul 2003
    Keep it as a spare
    Here is a photo of mine after 80,000km 8O
    And I quote:
    "every moment is another chance"
    Mahn England
    Ex 300Tdi Disco:
    well that fella's had a thrashing.
    Simon
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    Originally posted by one_iota
    Keep it as a spare
    And I quote:
    Hey Mahn,
    That was close to changing from a belt to a strap, you know with 2 ends not joined 8O 8O 8O 8O
    Defender200Tdi Guest
    Oooh..300tdis...timing belts. Makes me appreciate the raucous carcophony from my old 200tdi. :wink:
    Paul
    SYDNEY -in the shire.....
    <span style="color:blue">hey simon....that belt dont look too bad.....
    just check the new one in a few thousand kms....(if its easy to get to)...
    just to be sure its fitted correctly......
    the used belt is always good to carry as a spare for trips.....
    however..if a new belt is only around the thirty dollar mark....
    (probably not for a land rover).....its better to carry a new one....</span>
    [quote=DEFENDERZOOK]<span style="color:blue">hey simon....that belt dont look too bad.....
    Yeah, I was thinking about keeping it.
    Then I thought that if the old one snapped the LR wouldn't be going anywhere soon. Is this not the case?
    Simon.
    <span style="color:darkred">you may not use it as a timing belt.....
    when you break down in the bush...you will be surprised what uses you find for different things....</span>
    Jul 2003
    Originally posted by seqfisho
    Hey Mahn,
    Not a good look.
    The modification kit was fitted at the same time as this belt was changed.
    I just hope they were aware of the changed torque setting prescribed otherwise I might be photographing a strap next time.
    Mahn England
    Ex 300Tdi Disco:
