Just thinking I did replace the steering wheel not long after purchase...
And I have this gap
Would I be right in assuming I’m missing something or I have the wrong steering wheel??
It hasn’t worked for ages...might have worked when we first got the defer either way looking to fix it.
What locks the blue piece to the steering column/shaft?
It works fine with me spinning it by hand but it doesn’t turn when the shaft turns.
And I have this gap
Msing the tags on back of the steering wheel that goes into the slots on the blue bit to turn it.
Yeah will need the tags on wheel to work.
Umm doesn’t look like they were ever on there....
Have sent a message to the supplier..finger crossed
 Wizard
						Supporter
						Wizard
						SupporterThey seem to work better without the rubber boot pushed into the plastic shroud thing...
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
It appears I should have removed the cancelling tab off my old steering wheel.....
Thanks to Mario for sorting
Yes, you need "2" in the above picture. And note that when installing it, the "arrow" on the blue bit should point at the stalk. The "2" can be moved relative to the wheel.
