Diesel or petrol? That appears to be for 200TDi engines in the RRC.
This is the V8 part no. : 90602072 - GASKET-CYLINDER BLOCK OIL PUMP
Hi All,
I'm looking for someone to help ID the correct gasket that I need for between the oil filter housing and the block.
I think I have found the right one, but just want to check as there is a bit of conflicting information on the net
The link to the gasket that I think is the correct one:
https://www.allfourx4.com.au/epages/...17010000014139
Thanks in advance
Hi Ron,
You're a gentleman, that's the one!
Greatly appreciated.
*sorry I should have mentioned. 3.9 V8
Dale
I would be chasing a genuine one, the aftermarket ones are too thick, doesn't do anything for the oil pressure....🙄
