Thread: 300 tdi engine swap
    Jun 2013
    Universe A
    300 tdi engine swap
    I will shortly be changing the engine in my defender, the one that's going in has apparently done 120k from new, have been wondering what jobs to do before refitting,
    I think doing the rear main seal would be a no brainer, but what else?
    in the wild New England, NSW
    Certainly is a low km engine - there would not be many 300tdis around with such low kms.
    In a case like this, assuming I was planning to keep it with an expectation of long term reliability, I would undertake preventative head gasket replacement (on time alone), I would recondition the head (valves), and I would replace the timing belt and idlers, the coolant pump, the P gasket, the viscous fan hub, and I would have the radiator rodded and intercooler cleaned.
    And I'm sure there are things I haven't thought of.
    Others will say it's all unnecessary and overkill on what should be a good engine, just take your chances and fix things as they malfunction .
    The 300tdi is a very straightforward engine to work on, either on a stand or in the car.
    I've been through Orroroo a number of times - nice town with your huge red gum tree, very helpful guy with tyres at the corner of Sixth (I think it was) St.
    Mar 2007
    Warwick Qld
    I wouldn't be inclined to worry about the head, at those kays. Just do the other bits that 87County mentioned, de-egr it, add both egt and decent temp gauge. Should be good for a few decades.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    I agree with donh's comments re the temperature gauge, I fitted a VDO capillary gauge to our D1 and it instantly shows variations that the OEM gauge ignored.
    Dec 2012
    Stuart Town
    Welch plugs, rear main seal and the seal at the front of the gear box input shaft. I would assume, if a manual, that you are replacing the clutch(including bearing and perhaps heavy duty fork).
    Tom.
    1996 Disco 1 300TDI manual - Lucille a cantankerous red head! :D
    1997 Disco 1 300TDI Auto - sold
    Jun 2013
    Universe A
    Quote Originally Posted by 87County View Post
    I've got another one with 31 000 now on the clock,I got it at 29000 and I'm a bit cranky as I didn't want to drive it but the drought has made me use it as a feed wagon puller, the 120 k one was I believe a vehicle rollover that just never got it back in the rd , repairable right off...
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by donh54 View Post
    No egr on an aus spec TDI.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2014
    Perth Western Australia
    As others have mentioned..
    *Wouldnt worry about doing head.
    *Do all the other engine items that have been suggested, including the clutch.
    *DO ALL the coolant hoses AND expansion tank/cap
    *If your radiator is only average, get the original copper one re-cored.
    *Degrease the **** out of the engine bay while its out.
    *Fit something for a low coolant alarm or
    *I fit on all my customer vehicles that have major transplants a engine watchdog tm2
    ENGINE WATCHDOG TM2, Engine Temperature Sensor and Low Coolant Alarm
    *When its all up and running nice, tweak the pump so its a bit more nippy
    Daz
    Jun 2013
    Universe A
    Quote Originally Posted by BathurstTom View Post
    Tom.
    Do you have a part number for the gearbox input shaft seal?
    I also Believe that many have used the rear main seal that turner engineering supply, is this correct? And have their been reports of these still leaking, or do they seem to fix the problem?
    Cheers James
    Dec 2012
    Stuart Town
    Quote Originally Posted by shack View Post
    Cheers James
    I think it is FTC5303. As to the rear main seal, I got one from Roverlord whatever he sent. It has worked fine. Just be careful to follow instructions and allow it to 'self centre' if that makes sense prior to tightening it into place.
    Tom.
