Results 1 to 10 of 24
Thread: I like the look of this one
    May 2015
    Williamstown, Victoria
    Build date 11th Oct 2003
    LROCV #1410
    Oct 2016
    Perth, AU
    Long way from Victoria?
    Also, I wouldn't buy a manual, even if it does have all the other fruit on it
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Free Again Thanks Dan
    Quote Originally Posted by veebs View Post
    Personal choice my friend
    Call me a dinosaur but i still prefer a manual But as i said personal choice
    St Helena,Melbourne
    1.13 MB
    It left the factory as a commercial vehicle minus the middle and 3rd row seats hence why its a manual, i dont believe a manual was offered in non commercial vehicles post D3.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2016
    Blackstone
    Quote Originally Posted by rangieman View Post
    I like manuals. I’ve only ever had manuals. I looked for a manual D3 at first but everything was auto so that’s what I got. I don’t regret it at all. Rock crawl without having to modulate the clutch. No gear changes on your run up the Nkgala Rocks bypass and if you do sports shift is so much quicker with less chance of bogging down. I’m not an auto convert. My next road car will be a manual. But for an off-road vehicle it makes so much sense.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Oct 2016
    Perth, AU
    Quote Originally Posted by SeanC View Post
    Exactly - you want a little red sports car, then the manual makes sense. Buy a 3t truck, and Auto all the way. Otherwise, you're just a dinosaur
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Bohica View Post
    Replace the dash with a metric one. My UK import manual D3 has a dual speedo, but the odo is in miles. Takes a bit of getting used to as the IID reports faults in KM.
    the trip computer can be switched as a preference though.
    May 2015
    I never thought I'd buy D4 as they are only auto out here. I prefer the manual, hence the D2. For a personal import you have to own the car for 12 months. I like the idea of driving to Singapore and then a ship to Darwin.
    LROCV #1410
    Dec 2013
    Melbourne at last
    There shouldn’t be any need to replace the speedo. My 2010 which I brought with me from the uk when we moved here, has a digital display for speed (as well as analogue) which can be changed from miles to kms via the menu. This also changes the odometer and fuel consumption readings to Aussie friendly versions as well. You still have the analogue speedo in mph of course.
    Regarding the manual gearbox. When I was looking to buy, the concensus appeared to be that they went through clutches very quickly, but that may just be internet hearsay (which I’m now passing on!).
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Cantthinkofone View Post
    =Regarding the manual gearbox. When I was looking to buy, the concensus appeared to be that they went through clutches very quickly, but that may just be internet hearsay (which I’m now passing on!).
    They do have a relatively small clutch for the amount of torque they can create. I can't see it being a long term problem for me, but I tend to cringe/wince when I'm in the car with someone else driving.
