I suggest that first you ensure that the Llams connectors are properly seated, then if the fault persists remove the Llams loom to determine if the fault still persists and therefore what to look at next.
 Master
						Master
						Hi All,
Anyone had these codes.
At first
C1A99-1C (6C) pressure sensor circuit – Gen electrical failure – circuit voltage out of range (this one cleared)
C1A08-1C(AF) pressure sensor supply – Gen electrical failure – circuit voltage out of range (this one comes back)
Its saying normal height only available. Vehicle still operates all the way up and down with LAMS without any issue so doesn't sound like the compressor. Its on a MY 2015 HSE model
Thanks in advance
 Swaggie
						Swaggie
 Master
						Master
						 Swaggie
						Swaggie
						It could also be a wiring / connector issue so worthwhile R&R'ing the sensor leads and the main compressor connector near the compressor.
