Results 1 to 10 of 13
Thread: Door top/bottom seal - which way round ?
    Jul 2016
    Hi All,
    The new door seals I bought that go between top and bottom door halves have a lip along the edge, see pic :
    The question, where does the lip go, inside or outside, and up or down ? I am presuming outside and down, but if anyone knows better, I'd like to know.
    Aug 2012
    Adelaide
    OR
    do they go inside and up? any water that gets on them would be channelled back out?
    I'm guessing.
    Narre Warren South
    The recess is for the pop rivet heads now you have to work out lip inside or out.
    Is it going to spend a lot of time in the rain or will it be mostly in the shed & out only in good weather ?
    When the door top is bolted to the door will the rubber seal evenly between the doortop & door ?
    I think outside looks better but I'm not sure it really makes much difference.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2016
    Guanaba, QLD
    The parts catalogue is no help. It appears to have a bead on both edges, which seems to me to be an ideal way to hold water, and rust out the window frame quick-time...
    I'd be going inside and up.
    Peter.
    Jul 2016
    Thanks guys !!
    With the rubber placed with middle groove for rivets facing down, that means the lip points up, so the choice is lip facing up inside, or lip facing up outside. If I put it on the outside I guess that could become a water trap, so I'll go with lip facing up on the inside.
    Jul 2012
    Hello from Brisbane.
    I’m a little confused about “rivets downwards” - the seal attaches to the upper half the door from below.
    Probably like going “up to Sydney” or “down to Sydney” from a fixed position.
    Neil
    Jul 2016
    Hi Neil,
    One one side, the seal has a groove along it's length about half way across the rubber. The side with the groove faces the bottom door half, and side without groove faces top half of the door.
    Jul 2012
    Quote Originally Posted by JohnboyLandy View Post
    Hi Neil,
    Yes,
    I got that - it was the direction of the rivets that had me curious.
    The tops are off my doors at the moment. I could have a look in daylight to see how the rubbers are mounted lip-wise.
    Neil
    1975 S3 88" - Ratel
    Inside.
    Aug 2012
    Adelaide
    Inside.
    Fella's if John says inside then inside it must be! He is the series guru!
