Results 1 to 10 of 12
Thread: I want to make a DIY Tropical (or Safari) roof for my County. Has it been done before
    Feb 2010
    sydney
    Hello wise forum.
    I’ve just bought an Isuzu county with the three external ribs on the roof. The previous owner had glued and riveted a couples of racks and a solar panel directly to the roof and after removing all of the stuff I am now left with about 50 - 60 holes in the roof of various sizes.
    Instead of paying to get the roof fixed and resprayed (expensive) I’m considering sealing all the holes and covering the lot with a Tropical (or Safari) roof made from checker plate marine alloy. I’d like to make it strong enough to carry loads which I think could be achieved if a fasten the checkerplate directly to the roof ribs as well as having gutter mounted roof rack legs attached to the left and right outside edges.
    I’ve searched the forum and have found the odd reference to people planning something similar but have not found reference to anyone actually doing it.
    Does anyone know if this or something similar has been done before?
    Do I run the risk of making the roof structure too rigid and causing stress to seals or joins elsewhere in the body? Seems to happen to some using just roof racks.
    Brisbane, Inner East.
    Make life easy. Go to a wrecker and get a Series III station wagon roof and tropical roof. Tropical roof was standard on SIII wagons.
    URSUSMAJOR
    Crafers West South Australia
    I would not attach any plate directly to the ribs, you would still lack strength. I'd get a sheet metal shop to bend up some aluminium Z shaped rails, rivet and seal them to the roof, then add the new plate about 40-50mm away from the roof.
    Feb 2010
    sydney
    Why do you advise against attaching to the ribs? Would this add strength to the design?
    Also, is there an advantage to the Z bent design? Or could I achieve the same outcome using aluminium rectangular profile?
    Mar 2012
    Armstrong Creek, Qld
    Perhaps another thing to consider is using "Dimpled" plate instead of "Chequer". It's like a golf ball surface.
    Why I say this is because a bloke I go camping with occasionally has a camping canopy on his Patrol and it is dimpled aluminium plate. After some advice from his welder and by doing some simple, pre-construction, temperature tests he found it was noticeably cooler than chequer plate and, after sticking my head inside the canopy on a rather hot day, I won't contradict him.
    Steve
    Quote Originally Posted by alittlebitconcerned View Post
    What gives you the strength is the distance between the top and bottom surfaces of the roof sandwich, just like a bridge girder or a builders metal plank. Close together will just buckle under load. The Z sections are there to make riveting easier, as you can get full access above and below. Box section means no access from above for the bottom sheet unless you drill it full of holes. And an excessive number of holes to fill gives vermin more places to set up shop and more opportunities for whistles to arise. You could use C section or box tube cut in half but that still makes riveting more difficult. IMHO you want enough room up there to shove/pull a bundle of rag through to clean out any funny bits of shrubbery left there by four legged fiends.
    Jun 2018
    Redesdale
    Don't forget the roof is not designed to take any real load at all it has no vertical strength in it.
    The ribs are there to keep the roof straight and sturdy and to attach a lightweight safari roof to.
    If you want to carry a load anything you design should be supported off the gutters only or have a roll bar underneath in the cab and loadspace to take the load from above. Just because some fool attached a rack to the ribs dosnt mean you should also.
    The gutters are strong as and the more supports the better.
    I have 4 on each side of my disco1 and I can carry over 50 3m sticks of pine on it over speed humps and all. It's just a bit high up the only weight issue is with body roll so not really advised....
    Sorry I missed the tiny little part where you mentioned the gutters.
    Brisbane, Queensland
    Gutters also sag with excess weight on a 110 roof.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jun 2018
    Redesdale
    Quote Originally Posted by rar110 View Post
    I've had this fear with the disco.
    At least with the series/def the roofline is much straighter than the disco, you can run a horizontal support like a 20mmx3mm on edge along the whole gutter length. I've been meaning to do this to my disco so it spreads the load rather than supported by 100mm on each leg.
    Cheers jim
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    While I fitted a home made tropical roof to my Series 1 about 55 years ago, it would never have occurred to me to even consider it as load carrying.
    As mentioned above, the roof is not designed for load carrying, and even with a roof rack putting load onto the gutters, the load that can be safely carried is limited - from memory about 150kg including the rack. Overloading is likely to lead to cracking of the gutter members, side pillars and panels, especially on corrugated roads. The fact that some have managed to get away with it does not mean that it is a good idea! (And the height of the vehicle makes carrying significant loads on the roof a real impact on roll stability.)
