Results 1 to 10 of 37
Thread: TDV6 Life Expectancy ????
    Jun 2015
    On the road full time
    Thumbs down TDV6 Life Expectancy ????
    How long would you expect a 2010 D4 TDV6 engine to last. Mine has imploded at 215,000 km and I don't feel this is reasonable.
    All servicing done as per requirements by authorised Land Rover dealers.
    At $40,000 for a new engine I am not happy.
    Am I unreasonable?
    St Helena,Melbourne
    1.13 MB
    A fer members with 2.7's that are over 500k so 215k is definitely not reasonable, i would be pushing for a new engine from LRA as there are known issues with cranks snapping etc.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Ean Austral Guest
    Not acceptable at all but even more crazy is the 40k price tag for an engine swap.
    as has been said if dealer serviced at correct intervals then contact L/R .
    Cheers Ean
    Oct 2012
    Rule of thumb was if you make it to 200k kms it’s would go on and on. Maybe it’s 215k kms. I’m at 198k kms TDV6 Life Expectancy ????
    I’ve seen Ford Territory new Lion V6 engines for around $10k as a new option. Plus fitting. Same engine only with a few bits needing changeover from your engine.
    NEW GENUINE FORD SZ TERRITORY 2.7L LION V6 DIESEL ENGINE 276DT | eBay
    A second hand Territory V6 low km engine is the next step and there seems to be an independent repairer in each state skilled at the swap over.
    I’ll be really interested to hear what LR say but that $40k is the dealer rate for sure.
    Mar 2016
    It’s funny (not for you I might add) really as LR do believe that that’s the life of the car. This come from their view that the gearbox is “filled for life” or 10 years or 230,000km.
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by PerthDisco View Post
    No good for a 3ltr replacement.
    1974 VW Kombi bus
    Oct 2012
    99% sure 2010 tdv6 was 2.7
    St Helena,Melbourne
    1.13 MB
    I think it was the change over year, also I thought it read as a 2014.
    1974 VW Kombi bus
    NSW SW Slopes
    MY10 had both 2.7 and 3.0, with the 3.0 badged TDV6.
    What happened with the engine?
    Mar 2016
    So not correct. Mine is a 2010 TDV6 and it’s a 3.0L full power. It was only in later years when they ditched the 2.7 that they went to TD and SD spec where the previous TD 3.0L spec became the SD spec.
    2007 Audi RS4 (B7)
