Results 1 to 10 of 21
Thread: Ohh dear, where has all the power gone?
    May 2012
    Adelaide Hills, SA
    Symptoms, lack (total) of performance at low revs, even had to take a run up to get onto my drive way and that's not steep.
    D3, 2.7 diesel with a Black Box computer tweak, 270,000 K.
    It has felt like it was trying to start off in third gear it is that sluggish, off to the indee.
    Now all the symptoms and effects.
    Sluggish off the mark, will not hold speed on hills, turbo is not working correctly them power comes on and off we go, trailing huge clouds of black smoke. The smoke can be overcome by backing off or dropping a gear or two, getting the revs up.
    My workshop can't look at it for several days yet, they are booked out that far in advance (it's been there a week already), they are suggesting either a stuck open EGR valve or the turbo variable side is stuck in the fast lane!
    My problem with both these diagnoses is that when it is 'going' it is putting out so much black smoke and really feels as though the turbo is doing it's job..
    Can anyone shed any light on this matter, had it happen to their V6 diesel and if so what was the outcome?
    Can't say I'm looking forward to the bill either.
    Mike
    Jul 2013
    Possible split turbo hose
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    May 2012
    Adelaide Hills, SA
    Looked at that
    Surely that would show up when the turbo is really working.
    That was the workshop's first 'hope' but they looked at the hose, said they were hard but not at fault.
    Mike
    May 2009
    West Gippsland - Victoria
    Black smoke = oil, white/grey smoke = unburnt fuel. Perhaps turbo seal fail with lubricating oil being burnt ?
    Deano
    66 SIIA SWB .......73 SIII LWB diesel wgn
    86 RR 'classic'......99 Range Rover P38a
    94 Defender 110..95 Defender 130 Ute
    96 D1 300TDi.......99 D2 TD5 (current)
    04 D2a Td5..........02 Disco 2 V8
    Kingston, Tassie, OZ.
    Split IC hose is always my first check with those symptoms... followed by EGR open
    May 2012
    Adelaide Hills, SA
    Please explain!
    Thanks Justin, but can you explain to me why no power down low when the pipe wouldn't have much pressure therefore split closed, no whistle or escaping air noise when it does pressure up. I just can't get my head around it.
    Mike
    Jun 2010
    Central Coast NSW
    Quote Originally Posted by DeanoH View Post
    Deano
    I thought blue smoke was oil, black smoke was unburnt fuel and white smoke was a busted turbo or water in the oil.
    Sep 2009
    Quote Originally Posted by Disco-tastic View Post
    Black smoke equals partially burnt diesel, white is fully unburnt diesel or water. If white and diesel, usually an injector issue.
    May 2012
    Adelaide Hills, SA
    EGR valve
    Well it was the EGR valve stuck open but the price of parts is staggering, $165 for a blanking plate and $65 for the gasket!!!!!!!!!!!!!!!!
    Cheers and thanks to those who assisted.
    Mike
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by nismine01 View Post
    Mike
    blanking kits can be found for about $35 on ebay ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
