Results 1 to 10 of 18
Thread: What size is the hub nut?
    Bought some bearings just in case for Easter, but I suspect I haven't got a socket big enough..
    Anyone know offhand? Its an Xtreme.
    TIA
    Max P
    Avoca Beach
    Most are 52MM, and there is a tube spanner available from any specilialist for under $20. You do not need a socket as it doesn't have to be tight. I have never had a problem with the tube.
    Regard s Philip A
    Warburton, Victoria
    Fourwheeldrives in melb have them for about $15
    CROMER, NSW
    max
    speak to your friendly neighbourhood parts guy at alto, he's just bought one and welded a socket fitting to it, he might be able to point you in the right direction
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
    Melbourne - Eastern sector
    i bought one about 6 months ago for 8 buks!!
    South Yundreup,WA.
    As said they are about 52mm or 2". The Toyota standard item will fit but is slightly loose. Prices vary on quality from under $10 for a chaep nasty jobby to about $75 for one with a lifetime warranty. Depending on how they have been fitted a crack bar comes in handy.
    The ones I am talking about use a 1/2" drive socket to drive them using a ratchet or a crack bar or similar.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Mullion Creek, NSW. 2800
    Re: What size is the hub nut?
    TIA
    Max P
    Max,
    Graeme Cooper sells a very good quality h/d one, I've used it a number of times quite easy with large screw driver through end of tube to tighten.
    Bryce
    Nanny state UK...
    Get yerself a pukka box type one... As the others have said, they're very cheap & just makes life easier. Just remember that when assembling, just don't overtighten! I was taught to do them up as tight as you can and then back off 1/8th of a turn.
    Mark
    Avoca Beach
    I have evolved a method whereby I do the nut up with the spanner to only about 5ft lbs. Then I back it off and do it up finger tight ie only fingers on the nut without the spanner.
    That seems to be perfect with no pad knock back and no failed bearings for 5 years anyway.
    regards Philip A
    NSW far north coast
    hang on fella's ! Td5 'fenders are different !
    I don't know what size the hub nut is, but it's supposedly a one use only nut (no locknut) and it's done up to 210Nm/150lb/ft !
    The hubs in these things use a spacer tube between the bearings.
    I just use my old Jeep socket on the 300Tdi ones, 2,1/16" I think it is, and do it as per the book.
