Results 1 to 10 of 17
Thread: John Deere ride-on, what petrol to use?
    Queensland
    Hi folks, I have just received back a John Deere LT155 ride-on lawn mower.
    The Manuel states to use 87 octane petrol, but I keep 98 octane for my generator, mowers, and weed-eaters.
    I am no mechanic so can I use the 98 in the ride-on or will this cause problems?
    Jun 2018
    Redesdale
    You may possibly need an additive for leaded fuel, mind you ive ran 98 through a really old Howard (60's) withought an issue.
    Cheers Jim
    May 2008
    Bundaberg Qld
    nothing with ethanol in it.
    Queensland
    Thanks Jim and I forgot to post the manual states 87 unleaded octane.
    I warned you I am no mechanic!
    Nov 2014
    Nirvana near Albany W.A.
    Hi
    Your John Deere manual will be stating the US octane rating (AKI ), Australia uses RON ( research octane number) so the US 87 octane is the equal of 91 RON
    All your equipment will actually run better on 91 as it will all be relatively low compression stuff which has no knock sensors or ability to advance the timing to take advantage of the 98 you currently use
    99.87 MB
    It will run with whatever petrol you put in it. None of them will cause problems.
    Slunnie
    Kilmore, VIC
    106.38 MB
    Including E10...
    DiscoClax
    '94 D1 3dr Aegean Blue - 300ci stroker RV8, 4HP24 & Compushift, usual bar-work, various APT gear, 235/85 M/Ts, 3deg arms, Detroit lockers, $$$$, etc.
    '08 RRS TDV8 Rimini Red - 285/60R18 Falken AT3Ws, Rock slider-steps, APT full under-protection, Mitch Hitch, Tradesman rack, Traxide DBS, Gap IID
    in the wild New England, NSW
    Probably quite right - BUT, I think from memory, that in JD caution about using anything with ethanol in their current models.
    I use so little petrol these days I just get 98 when required, even for the mowers.
    Kilmore, VIC
    106.38 MB
    I'm a bit wary of ethanol in carby engines generally, but have run my 20yo Husky with Kwaka twin many times on it (like half the time or more) and after 500+ hrs it is still sweet as a nut. Kwaka say E10 is OK, and small amount of ethanol is good to emulsify any water and also clean the system. Best check the engine manufactures recommendation if unsure.
    DiscoClax
    NSW far north coast
    The problem with E10 is when it is stored in anything other than a metal drum as it will absorb moisture from the atmosphere.
    Actually any petrol in HDPE, etc is an issue when stored long term as the aromatics permeate the container wall and volatise off.
    I happily use e10 in the work Hilux but avoid using it in OPE where I'll use 95/98 just to avoid the ethanol.
