Results 1 to 10 of 33
Thread: about to galvanise my 110 firewall - anyone else done it?
    Toowoomba QLD
    Sorry if this has already been discussed before but I tried a search with no luck.
    My 110 firewall is now completlly stripped - what a job! and is now at the panel shop having some welding done - new footwells etc.
    It was my intention to have it hot dipped galvanised (I have previously galvanised a series 2A firewall with reasonably good results) but am having second thoughts due to:
    1. The 110 firewall doesn't seem as stiff as a 2A firewall which had more bracing in the center dash area, - it seems like it may be more prone to warping or twisting and
    2. There is more to lose if it is ruined in the process due to the money I am spending on repairing it, and the cost of replacing it
    Some reassurance from someone who has previously successfully galvanised a 110 (or series 3 as they are very similar) firewall would be appreciated. The risk free alternative is to sandblast it and paint in industrial primer, then fishoil all the internal cavities. The downside is that nothing beats galvanising for rust protection, especially after welding. I am also galvanising the chassis (it is also stripped and ready for sandblasting) with the intent of building a rover which will last me for at least the next 20 years.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    If warping / twisting worries you, weld a couple of stiffeners to it.
    38mm x 6mm flat bar on edge would be heaps i would think
    stitch welds only 5mm long in several places on each brace will be easy to remove and will be easy to rustproof with cold gal or whatever takes your fancy after removal.
    galvanising usually normalises steel so it can move anywhichway but can usually be put back where it was with some patience and a portapower and chain block or two.
    welding the footwells in will create some stresses to start with i would thing so it could be a good thing alround to galvanise it.. dam sure i would do mine if i had the bucks...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Lithgow, NSW
    Hey Mark,
    I have no experience in this but have every intention of hot dipping my Series 2a bulkhead when I have done the small repair welds to it. I have heard of others success in doing it with only a very slight warp across the panel where the vents sit ... it's thinner along there. One solution is to get the guys to leave your Bulkhead to the very end of the process when it's not as hot and extreme ... I believe they can actually control the process to a certain degree and still achieve the same results with less chance of warping.
    I'd have a good chat to the operator before you do the job and explain your needs. Where and how much did it cost you to get your Series B'hd done last time?
    Cheers, Simon.
    Toowoomba QLD
    Actualy its not that expensive. Around $60 to get a firewall dipped plus about $100 for the sandblasting. I wouldnt want to be paying someone for the labor to strip and refit it however..........
    I've got not the foggiest idea, but I wanna know, I wanna know.
    Keep us posted and piccied.
    Simon
    Toowoomba QLD
    Originally posted by Tikirocker
    Hey Mark,
    Cheers, Simon.
    I've already asked them about the cooler dip - apparently this is a myth as if it gets too cold the bath freezes - and they dont want that. The place I use (at Narangba on the north side of Brisbane) works 24 hours per day.
    The current rate is $1.20 per kilo of galvanised weight. A firewall only weighs about 25-30 kg. Galvanising might add about 3kg to it.
    I had some slight rippling in the 2A firewall which was hidden by the olive drab lusterless paint and a bit of difficulty refitting the windscreen frame. The captive nut plates for the door hinges in the 2A are a bit of a pain as they sieze up and make refitting the doors a bit of a challenge as well.
    G'day Mark,
    I don't know much about galvanizing firewall but was warned against it as risk of warping.
    I have a 110 firewall that needs repairing and treating. Have a look at POR15 paints. Very expensive as far as paint goes but a lot of car restorers are using it. There is a company in NSW that imports it. This is what I will be using.
    www.por15.com.au
    You also mention that they will be putting in new footwells. Have you been able to source these as only ones I can find are from Series firewalls and the footwell are different.
    Let us know what you have done.
    David
    Lithgow, NSW
    I believe our English cousins have had a long association with POR15 and there are some serious health risks associated with using the stuff so it might do for any potential users to make sure of the do's and don't of that stuff to guard against injury in the long term.
    May 2002
    Sydney, Australia
    I was told by the bloke in Brookvale, NSW not to gal the firewall - he is also a LR nut.
    He recommended blasting and then "organic" galvinised spray.
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Lithgow, NSW
    HTH
    LRH
    I assume by organic you can also just paint it with Cold Gal ... that's another option I am considering to avoid warping. You then paint over the cold gal.
